Hi Everyone,
I'm playing around with a local server.
trying to figure out this behavior.
the server uses encrypted .ts streams.
I can play the videos, and I am able to copy the streams with FFMPEG.
when I'm comparing the streams to the original, I see that my copy is from a lower quality stream than the one available.
when using the -map option on FFmpeg i get the following:
ffmpeg.exe -y -i "https://192.168.2.184/dty/1//Motor-asembly-part-1-34SDFS/index-f2-v2-a4.m3u8?st=DMZ_Da3546Bt54s&e=15487955" -map -c copy test1.ts
Input #0, hls, from 'https://192.168.2.184/dty/1//Motor-asembly-part-1-34SDFS/index-f2-v2-a4.m3u8?st=DMZ_Da3546Bt54s&e=15487955':':
Duration: 00:10:47.00, start: 0.101000, bitrate: N/A
Program 0
Metadata:
variant_bitrate : 0
Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 854x480 [SAR 1280:1281 DAR 16:9], 30 fps, 30 tbr, 90k tbn
Metadata:
variant_bitrate : 0
Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp
Metadata:
variant_bitrate : 0
Stream #0:2: Data: timed_id3 (ID3 / 0x20334449)
Metadata:
variant_bitrate : 0
Unsupported codec with id 98322 for input stream 2
It only recognizes the low-quality version.
while tube digger shows the following:
640X360 698K.ts
854X480 1627K.ts
1280X720 3123K.ts
1920X1080 6118K.ts
Any idea?
usually, FFmpeg recognizes all the available streams when using the -MAP option.
Thanks!
Results 1 to 1 of 1
VSDC doesn't recognize my fonts...
By Nivekian in forum Newbie / General discussionsReplies: 1Last Post: 26th May 2022, 11:02 -
D8 cam doesn't recognize Hi-8 tapes?
By clashradio in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 26th Feb 2021, 13:26 -
How to copy unsupported data streams with ffmpeg?
By mckfabio in forum Video ConversionReplies: 2Last Post: 12th Jul 2020, 11:44 -
FFMPEG - Copy empty streams
By vandalay22 in forum Video ConversionReplies: 0Last Post: 6th Nov 2019, 16:47 -
grabbing video streams ffmpeg
By lomero in forum Video Streaming DownloadingReplies: 65Last Post: 12th Oct 2019, 09:19
