i once had batch script for this and i losted it. would love to have it again but i cant find it anywhere.
If you're unsuccessful in finding or re-creating the script, there is such program as MKV Optimizer which will do what you're asking for albeit in a graphical user face rather than script. It can bulk do it also.
ill rather use batch scripts so if anyone can re-create or point me to direction i would be happy
i didnt find old mkvmerge one but managed to make working for mkvproedit (included also in mkvtoolnix)
for %%z in ("*.mkv") do mkvpropedit.exe "%%z" ^
--edit track:v1 --set flag-default=1 --set language=und ^
--edit track:a1 --set flag-default=1 --set language=engLast edited by MRHS; 3rd Oct 2022 at 06:25.
@MRHS
Thank-you for the mkvproedit code - I had no idea it could be used to edit mkv files
I had 100+ files that I wanted to change the default subtitles from Danish to English and it only took minutes.
Mkvmerge, batch to mkvmerge add multiple audio tracks
By SrBills in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2022, 00:40 -
MKVMERGE Batch Muxing multiple audio and subtitle tracks?
By jahob000 in forum Newbie / General discussionsReplies: 37Last Post: 22nd Dec 2020, 19:21 -
Mux audio and Video in Mkvmerge using Batch File
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2019, 05:30 -
batch Mkvmerge to select only the AC3 audio and ignore any AAC audio
By olpdog in forum EditingReplies: 3Last Post: 11th Aug 2019, 05:00 -
Batch Mkvmerge change default audio, subitle + delete audio
By alloar in forum Newbie / General discussionsReplies: 2Last Post: 8th Jan 2018, 16:38
