It seems it plays several 3 audio tracks simultaneously and first 2 of 3 even does not belong to the opened MKV file. I had never seen this before.
[Attachment 67037 - Click to enlarge]
[Attachment 67038 - Click to enlarge]
Code:General Unique ID : 71039988732363397557951602236894626339 (0x3571CDDD17C48A085A04390E6F464223) Complete name :<file.mkv> Format : Matroska Format version : Version 4 / Version 2 File size : 2.39 GiB Duration : 44 min 11 s Overall bit rate mode : Variable Overall bit rate : 7 732 kb/s Writing application : mkvmerge v70.0.0 ('Caught A Lite Sneeze') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, RefFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 44 min 11 s Bit rate mode : Variable Bit rate : 7 471 kb/s Maximum bit rate : 12.7 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.144 Stream size : 2.31 GiB (97%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced Audio Coding 3 Format settings, Endianness : Big Codec ID : A_EAC3 Duration : 44 min 11 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 187.500 FPS (256 SPF) Compression mode : Lossy Stream size : 80.9 MiB (3%) Language : English Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 43 min 59 s Bit rate : 89 b/s Count of elements : 550 Stream size : 28.9 KiB (0%) Language : English Default : No Forced : No ...
Thanks. So it seems it is loading with video all audio tracks with the same name...
Yes. Some people like to keep the video and audio in separate files. All the advanced players have a similar option for dealing with that.
Suddently MPC-HC & MPC-BE no video but got sounds, help!
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2022, 05:57 -
Strange behaviour: Terratec Grabster AV 350 MX, Virtualdub
By Jupit0r in forum CapturingReplies: 18Last Post: 30th Mar 2021, 10:43 -
sync offset and jitter values in mpc-hc and mpc-be
By Milardo in forum CapturingReplies: 0Last Post: 16th Nov 2020, 19:29 -
why this behaviour in the same subtitle in difference devices
By jraju in forum Newbie / General discussionsReplies: 14Last Post: 15th Nov 2019, 07:44 -
XMedia Recode strange behaviour while hardcoding subs
By Patapin in forum SubtitleReplies: 3Last Post: 21st Jul 2019, 05:27
