Page 2 of 15
FirstFirst 1 2 3 4 12 ... LastLast
Results 31 to 60 of 424
    Sep 2006
    Ohio, United States
    If you currently use VAP (or VAP6, VideoReDoAutoProcessor program), (or even if you don’t) you may be interested in this:
    https://www.videoredo.net/msgBoard/index.php?threads/future-evolution-of-vap.38065/
    Reply here if you’re not on the linked VideoReDo forum. (It’s freeware BTW.)
  2. Member IsoBuster's Avatar
    Jan 2010
    Belgium & Australia
    > QSF (Quick Stream Fix)
    Give www.dvdvobtompg.com a try. Freeware and ONLY for mpeg2
    Not sure if it will work for this type of input, but worth giving it a try.
    Dec 2021
    Scotland
    VRD is an outstanding piece of software. I use it for editing video footage that I've recorded from a DVB tuner card in my PC. Two things that VRD does that most others do not:
    1. you can cut anywhere in the video, it doesn't have to be at an I-frame. VRD will do a mini recode around the cut to ensure video is good.
    2. it retains teletext subtitles after editing. I've found no other piece of editing software that does that.
    Also of course, it's so easy to use.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    TSDoctor does all the things mentioned by deccavox and is well supported.
  5. Member hydra3333's Avatar
    Oct 2009
    Australia
    OK, thanks.
    If you use it, could you share some working commandlines for mpeg2/TS -> mpeg2/mp4, and avc/TS -> avc/mp4
    which check for and fixes anomalies and maintains audio sync ?
    Cheers
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    OK, thanks.
    Cheers
    I don't do command lines! Gave that up decades ago am now a complete convert to point and click. Anyway no need with TSDoctor does it all from GUI. You decide it's actions. It's free to try for a month fully functional.
  7. Member hydra3333's Avatar
    Oct 2009
    Australia
    Ah. I'm a nerd from way back who loves scheduled tasks to automatically perform work for me ... and that means commandlines.
    With such things I can prepare TV recordings for timeshifted viewing ... without any clicks
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    i don't do command lines! Gave that up decades ago am now a complete convert to point and click.
    thank you!!!!!
  9. shhh, ai is listening. If anything happens and they take over, those who do not use gui, go first ....
    Mar 2023
    Belfast
    I have just purchased a new pc but can't find my registration key from some years ago. I've installed the trial version but guess that it will expire in a limited time (not used yet). Is there any way I can find it from my old pc's installation?
    Dec 2021
    Scotland
    Look in your emails (on any PC). Assuming you haven't deleted it, it'll be still there. Mine still is (I've just looked).
    Mar 2023
    Belfast
    I've already checked for VideoRedo but no luck. It could be an email I haven't used for a long time.
    Feb 2006
    see post #5 - https://videoredo.net/msgBoard/index.php?threads/help-finding-my-videoredo-software-key.1455/
    May 2005
    PAL User
    VideoRedo is still going strong here. I've just installed Windows 11 and was able to re-install my VRD and activate it.
    A big thanks to whoever is running VRD; it is a wonderful program and it would be a real shame for it to go.
  15. Originally Posted by netmask56 View Post
    Are you joking? TSDoctor has horrible user interface for editing videos. And is NOT well suppored. I have the latest version.
  16. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    For DVB-S and DVB-T recordings, for which the tool has been developped, is absolutely the best. Period.
  17. Originally Posted by lollo View Post
    May be for removing errors from recordings. But NOT his gui for editing videos. And, for example, my recordings don't contains errors.
  18. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    That's its goal
    It is not a NLE
    To establish that, you need a TSDoctor pass using "Check Only" mode. Then you can do any manipulation you wish with your favourite tool
  19. To establish that, you need a TSDoctor pass using "Check Only" mode. Then you can do any manipulation you wish with your favourite tool
    Yes, of course. But VideoRedo has similar mode for removing only errors from recording (Menu->Tools->QuickStream Fix...). But I prefer to record without errors , then no need any Check/Fix mode...
  20. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Not as effective
    You do not control the bad wheter, the problems of encoding at broadcaster side, the problems of some sun activity interfering with the satellites, the problem of rection at your side, and so on
    Always check your recordings with TSDoctor, even if they apparently do not show evident errors
  21. Always check your recordings with TSDoctor, even if they apparently do not show evident errors
    I am recording from cable (DVB-C, DVB-T) over 10 years and without problems. And even VideoRedo itself does some error checking when it saves the edited video.
    For the vast majority of edited videos, the number of errors found is zero. And even if there is a small error, VideoRedo fixes it without any problems without breaking the synchronization of video and audio. I am extremely satisfied with VideoRedo. The most important thing is to have the best quality recording. If you don't have it, even TSDoctor won't help you (with extensive error you can throw such a recording away anyway).
  22. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Of course.
    But having the best recording does not entirely depend on you, especailly for DVB-S transmission.
    In any case, when errors are present in the recorded streams (teletext, subtitles, additional audios, video streams, switching audio format from MPEG to AC2, etc), TSDoctor handle them in a more effective way, like TSReader, because they have been designed for DVB recordings.
  23. In any case, when errors are present in the recorded streams (teletext, subtitles, additional audios, video streams, switching audio format from MPEG to AC2, etc), TSDoctor handle them in a more effective way, like TSReader, because they have been designed for DVB recordings.
    You were responding to my sentence >TSDoctor has horrible user interface for editing videos< and this is still valid.
  24. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Re-read post #48
  25. Re-read post #48
    Re-read post #45.
  26. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Re-read post #48
    Re-read post #45.
    Re-read post #46 then, stop this non sense, and use whatever you want, without denigrate specific software dedicated to specific goals (that you probably do not understand)
  27. Re-read post #46 then, stop this non sense, and use whatever you want, without denigrate specific software dedicated to specific goals (that you probably do not understand)
    I did not start discuss about error correction in recordings! I only tell - TSDoctor has horrible GUI interface for editing video (cuting) and this is true (because I used it, therefore I can compare). This is for you denigrate specific software?? Then you have personal problem. Not I, but you probably don't understand. And why you still react to responses? Do you want to have the last word because your vanity wants you to?
  28. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Yes
  29. Yes
    Then you're an ass***e. Bye.
  30. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Same as you, idiot. Bye
