Hello!
I get an error when I'm trying to encode x265 video using ffmpeg:
The problem seems to be that my computer is unable to keep up with real-time encoding, which I don't even want. I am encoding pre-recorded videos so I don't need real-time encoding.Code:[s16le @ 0x562a29c99c40] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
Here is my command:
I have tried several suggestions to fix this which I found:Code:fceux --subtitles 0 --slstart 0 --slend 239--xscale 1--yscale 1 --special 0 --pal 0 --sound 1 --soundq 1 --soundrate 48000 --volume 150 --trianglevol 256 --square1vol 256 --square2vol 256 --noisevol 256 --pcmvol 256 --mute 1 --nospritelim 1 --no-config 1 --loadlua exit.lua --palette QuickNes.pal --videolog ffmpeg -ar 48000 -channel_layout mono -f s16le -i "s.log" -f rawvideo -pix_fmt bgr24 -r 60.0998 -s 256x224 -i - -c:a libopus -channel_layout mono -compression_level 10 -b:a 64k -c:v libx265 -crf 20 -pix_fmt gbrp -preset veryslow "output_video.mp4" --playmov "input_video.fm2" "rom_file.nes"
https://stackoverflow.com/questions/63566988/thread-message-queue-blocking
https://stackoverflow.com/questions/61723571/correct-usage-of-thread-queue-size-in-ffmpeg
So I have tried to move the "-r 60.0998" option to the end of the command. I have tried to add the option "-thread_queue_size" after each input file and tried several different values such as 16, 128, 1024 and even 4096. Can someone help me to get rid of this error?
Another
Results 1 to 11 of 11
Well that error did disappear, but now I have another one:
Code:s.log: Invalid data found when processing input write: Broken pipe
What is s.log as input?-i "s.log" -f rawvideo -pix_fmt bgr24 -r 60.0998 -s 256x224 -i - -c:a libopus
The second input (-i) is empty.
It seems to me that the whole command line is pretty messy. -
Then this part of code should be
(input, then filters and arguments)ffmpeg -i - -f rawvideo -pix_fmt bgr24 -r 60.0998 -s 256x224 -i "s.log" -ar 48000 -channel_layout mono -
I tried to change this as you suggested. Everything seems to start okay, but now the emulator only shows the first frame and stops there. Also the encoder does not seem to encode any frames:
But if I change the audio first:Code:ffmpeg -i - -f rawvideo -pix_fmt bgr24 -r 60.0998 -s 256x224 -i "s.log" -ar 48000 -channel_layout mono -c:v libx265 -crf 20 -pix_fmt gbrp -preset veryslow -c:a libopus -b:a 96k -channel_layout mono -compression_level 10 "output.mp4"
I get an error:Code:ffmpeg -i "s.log" -ar 48000 -channel_layout mono -i - -f rawvideo -pix_fmt bgr24 -r 60.0998 -s 256x224 -c:a libopus -b:a 96k -channel_layout mono -compression_level 10 -c:v libx265 -crf 20 -pix_fmt gbrp -preset veryslow "output.mp4"
I wanted to add one more detail, the command has been modified using this as a guide:
https://tasvideos.org/EncodingGuide/VideoDumping#Linux_4 -
Try
Atfceux --subtitles 0 --slstart 0 --slend 239 --xscale 1 --yscale 1 --special 0 --pal 0 --sound 1 --soundq 1 --soundrate 48000 --volume 150 --trianglevol 256 --square1vol 256 --square2vol 256 --noisevol 256 --pcmvol 256 --mute 1 --nospritelim 1 --no-config 1 --videolog "ffmpeg -f s16le -ar 48000 -channels 1 -i /path/to/soundpipe/s.log -f rawvideo -r 60.0998 -s 256x224 -pix_fmt bgr24 -i - -c:a pcm_s16le -c:v libx264rgb -qp 0 -pix_fmt rgb24 output.mkv" --playmov input_video.fm2 rom_file.nes
/path/to/soundpipe
insert the correct path to s.log -
I'm sorry, I have tried with relative and absolute paths in each file without success. Now I this like you suggested:
And I still get the error:Code:fceux --subtitles 0 --slstart 0 --slend 239 --xscale 1 --yscale 1 --special 0 --pal 0 --sound 1 --soundq 1 --soundrate 48000 --volume 150 --trianglevol 256 --square1vol 256 --square2vol 256 --noisevol 256 --pcmvol 256 --mute 1 --nospritelim 1 --no-config 1 --loadlua "/path/to/exit.lua" --palette "/path/to/QuickNes.pal" --videolog 'ffmpeg -f s16le -ar 48000 -channel_layout mono -i "/path/to/s.log" -f rawvideo -r 60.0998 -s 256x224 -pix_fmt bgr24 -i - -c:a libopus -b:a 96k -channel_layout mono -compression_level 10 -c:v libx265 -crf 20 -pix_fmt gbrp -preset veryslow "output_video.mp4"' --playmov "/path/to/input_video.fm2" "/path/to/rom_file.nes"
Code:[s16le @ 0x557d650cec80] Thread message queue blocking; consider raising the thread_queue_size option (current value: 8)
-f s16le cannot work with -c:a libopus
eitheror-f s16le -c:a pcm_s16leonly-c:a libopus
FFMPEG x265 encoding wrong settings for some sources
By tony95 in forum Video ConversionReplies: 4Last Post: 10th Dec 2021, 12:11 -
x265 2-pass error using FFmpeg Batch AV Converter
By pascor in forum Video ConversionReplies: 20Last Post: 19th May 2021, 07:40 -
error message
By hellox9 in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2020, 04:17 -
Startup error message
By bevills1 in forum ComputerReplies: 13Last Post: 23rd Sep 2020, 10:35 -
Honestech 3.0 Error Message
By myladydeb in forum Newbie / General discussionsReplies: 0Last Post: 16th May 2020, 15:20
