I suspect this is the wrong place to post this but I did not see anything specific to webcams.
I am attempting to connect two webcams (Logitech C-920 & C-922) to my Dell XPS13 (i7 Win-10) laptop via USB-A to record music practice sessions via OBS Studio. This machine only has two USB-A ports (one USB-C); I need access to at least three USB-A ports (2 cameras + an audio interface). Therefore, I would like to connect the webcams to a 4-port USB hub. However, when doing so I am only able to view one camera at time; the other remains blank. I disabled the laptop’s onboard camera thinking this may help but still only one camera at a time. If I plug one camera into the hub and one directly into a port on the laptop it works fine. If I plug both cameras directly into USB ports on the laptop it also works fine.
In the past the 4-port hub worked fine with my old Win-7 i5 HP Pavilion laptop. I suspected a newer, faster, more powerful, etc. machine would have worked better not worse. I understand trying to connect numerous webcams could be a problem but I would think simply hooking up two to a newer computer would not be an issue. Oh well. . .
Any suggestions would be appreciated.
Results 1 to 10 of 10
Is your usb hub connect to your laptop via usb A or via usb C. Am pretty sure the C port would have greater bandwidth, and that might be what is limiting usage of 2 cams. You might need to get a different hub to accommodate this, though.
Scott -
Moved the thread to computers where you can get more help.
I did see that thread. It's a bit confusing since it states Win10 does not recognize two cameras. However, I have Win10 on my older HP and it works fine so I don't think its an OS thing. Maybe a powered USB hub would help. I'm going to try that next.
Thanks for your suggestion and concern - again, much appreciated. -
USB A --> C adapter will not help w/ bandwidth issues, because the hub would be the limiting factor here, unless that hub is USB A v3.0 or maybe even v3.1.
I'm betting you need something like this: https://www.amazon.com/Anker-HDMI-Adapter-Bundle-PowerExpand/dp/B08ZCC9DFM/ref=sr_1_30...%2C105&sr=1-30
Scott -
UPDATE -
Thanks everyone for your suggestions. I cut to the chase and did a complete Win10 reinstall. What a pain but all is working fine now. So apparently it was some OS setting or possibly a driver that was causing the problem. Oh well, I'm back in business.
Thanks again,
Steve K.
connecting mpg files
By LM3 in forum Video ConversionReplies: 1Last Post: 17th May 2020, 18:53 -
Download MP4box not connecting
By IanOW in forum Video Streaming DownloadingReplies: 2Last Post: 5th Nov 2019, 02:01 -
?s about Connecting Laptop to HDTV
By sdsumike619 in forum Newbie / General discussionsReplies: 13Last Post: 19th Oct 2019, 16:21 -
RTMPDump Hangs at Connecting ?
By PowerFalcon in forum Video Streaming DownloadingReplies: 1Last Post: 8th Apr 2018, 05:09 -
Need advice on connecting computer to TV
By Aldbaran in forum Newbie / General discussionsReplies: 17Last Post: 27th Mar 2018, 20:51
