Why is this video so strangely described (bold), what's the point?
MPC recognizes this as Full / BT.601. Correctly?
Video
Format : AVC
Format profile : Baseline@L4.1
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 27 s 978 ms
Source duration : 27 s 959 ms
Bit rate : 21.9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.543 FPS
Minimum frame rate : 10.004 FPS
Maximum frame rate : 30.303 FPS
Real frame rate : 30.000 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.357
Stream size : 73.0 MiB (99%)
Source stream size : 73.0 MiB (99%)
Title : VideoHandle
Language : English
Encoded date : UTC 2022-07-15 11:53:09
Tagged date : UTC 2022-07-15 11:53:09
Color range : Limited
colour_range_Original : Full
Color primaries : BT.709
colour_primaries_Original : BT.601 NTSC
Transfer characteristics : BT.709
transfer_characteristics_Original : BT.601
Matrix coefficients : BT.709
matrix_coefficients_Original : BT.601
mdhd_Duration : 27978
Codec configuration box : avcC
No, it's BT.709, limited.MPC recognizes this as Full / BT.601. Correctly?
The video analyzed is BT.709, color range limited (probably resized), but was encoded from source BT.601, color range full.Color range : Limited
matrix_coefficients_Original : BT.601Last edited by ProWo; 27th Sep 2022 at 09:59.
_Original = flags of the stream
without the _Original = flags of the container
-> remuxing without the container flags should help.users currently on my ignore list: deadrats, Stears555, marcorocchini -
It is definitely not limited, because Vegas also recognized it as full (see attachment).
This is a video file from my phone.The video analyzed is BT.709, color range limited (probably resized), but was encoded from source BT.601, color range full.Color range : Limited
matrix_coefficients_Original : BT.601Last edited by rgr; 27th Sep 2022 at 15:52.
ffmpeg Color Range
By chris319 in forum Video ConversionReplies: 327Last Post: 15th Apr 2024, 14:58 -
VirtualDub2 + x264vfw = color range problem in output mp4
By rgr in forum Video ConversionReplies: 13Last Post: 6th Jul 2022, 16:45 -
Adjusting color saturation of color range
By Ygramul in forum Software PlayingReplies: 3Last Post: 24th Jan 2021, 09:07 -
USB3HDCAP - Problem With Output Color Range on Composite
By Powerstars in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2020, 16:32 -
MPC-HC: Output dynamic range / black level / color range stuck? Washed out
By vlad992 in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2020, 07:54
