All I want to do is add a fade to black to the end of a short 30 second clip. No matter what, every single time I export this clip in AVS after adding the fade the video freeze-frames right before the fade occurs even though it doesnt do that when I watch it in the editor itself. No matter what format or codec I export it in it always comes out with the exact same freeze-frame that's not supposed to be there, what do I do,?
Results 1 to 1 of 1
Subtitle issue with avs to dvd
By tmaxgo404 in forum Authoring (DVD)Replies: 18Last Post: 27th Sep 2022, 16:34 -
Colour of video changes when using FFMPEG with AVS Script
By bradwiggo in forum Video ConversionReplies: 5Last Post: 3rd Jul 2021, 06:51 -
Removing Annoying Voice From Home Video (VSDC Pro)
By chiques in forum EditingReplies: 1Last Post: 27th Dec 2020, 15:18 -
VirtualDub2 .avs no video stream found issue
By Fraugster in forum EditingReplies: 4Last Post: 10th Aug 2019, 18:20 -
Audio makes annoying click in VSDC Editor
By Scott Musil in forum Newbie / General discussionsReplies: 2Last Post: 4th Nov 2017, 19:33
