  1. I have tried to obtain key and download from this website:
    http://www.comoverfutbol.com/en-vivo/tvn/
    but it is protected and encrypted in a particular way, I have your mpd link but it hasn't been possible for it to work either
    https://dtvott-abc.akamaized.net/dash_live_1221/manifest.mpd
    C:\Widevine>yt-dlp --external-downloader aria2c --allow-unplayable-formats -F "https://dtvott-abc.akamaized.net/dash_live_1221/manifest.mpd" -v
    [debug] Command-line config: ['--external-downloader', 'aria2c', '--allow-unplayable-formats', '-F', 'https://dtvott-abc.akamaized.net/dash_live
    _1221/manifest.mpd', '-v']
    WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging.
             If you experience any issues while using this option, DO NOT open a bug report
    [debug] Encodings: locale cp1252, fs utf-8, out utf-8 (No ANSI), err utf-8 (No ANSI), pref cp1252
    [debug] yt-dlp version 2021.12.01 [91f071a] (win_exe)
    [debug] Python version 3.8.10 (CPython 64bit) - Windows-8.1-6.3.9600-SP0
    [debug] exe versions: ffmpeg N-104766-g3a9861e22c-20211205 (setts), ffprobe N-104766-g3a9861e22c-20211205
    [debug] Optional libraries: Cryptodome, mutagen, sqlite, websockets
    [debug] Proxy map: {}
    [debug] [generic] Extracting URL: https://dtvott-abc.akamaized.net/dash_live_1221/manifest.mpd
    [generic] manifest: Requesting header
    WARNING: [generic] Falling back on generic information extractor.
    [generic] manifest: Downloading webpage
    [generic] manifest: Extracting information
    ERROR: float() argument must be a string or a number, not 'NoneType'
      File "yt_dlp\YoutubeDL.py", line 1329, in wrapper
      File "yt_dlp\YoutubeDL.py", line 1398, in __extract_info
      File "yt_dlp\extractor\common.py", line 597, in extract
      File "yt_dlp\extractor\generic.py", line 2693, in _real_extract
    Jan 2021
    Argentina
    Update yt-dlp. They fixed that issue a few months ago.
    yt-dlp --update
  3. also
    is old code. now use simply
    --allow-u
    and -v after mpd link is for ... ?
  4. Originally Posted by lomero View Post
    -v, --verbose Print various debugging information
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  5. Originally Posted by lfer94 View Post
    yt-dlp --update
    yes thanks with that it is solved
  6. Originally Posted by lomero View Post
    also
    --allow-u
    Thank you
    everything is part of a bat that I found on reddit
  7. Originally Posted by LZAA View Post
    Url?
    the url is
    https://www.comoverfutbol.com/en-vivo/tvn/
    make sure that https is written so that the web works in chrome
    this is the mpd
    for me it worked better this way
    http://dtvott-abc.akamaized.net/dash_live_1221/manifest.mpd no s
    I can't get the keys:
    PSSH: AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEOHeWA/EM1nemshqAZF4hqY=
    License URL: https://connect-metrics-collector.s-onetag.com/metrics
    unable to parse license - check protobufs
    maybe I'm wrong with the url license
