Curerently running win 98 with ati capture card. Capture under a program called free vcr works really great since I am using vfw drivers. I want to upgrade to xp but I understand you have to use the wdm drivers which in turn free vcr won't work anymore. Can I still use my vfw drivers or what capture program do you suggest I try?? Thanks for any advice..
Windows XP comes with the VFWWDM wrapper so it should still work ok.
Craig
