I have a ton of old Chicago Bulls VHS tapes from the 90's, and a lot of them are transferring pretty good in my opinion.
I am however having some issues with certain tapes. I'm using a Panasonic DMR-EZ48V into a capture card.
I'm getting a lot of jump and jitter in the output on certain tapes. I'll attach a video link showing what I mean.
I often have strong vertical jump. While adjusting tracking, I can get less vertical jump at the cost of introducing noise on the bottom of the screen. If I use tracking to reduce the noise on the bottom, I get more vertical jump. There is also clearly horizontal jitter as well.
I'm outputting with S/VHS.
Do I need a different VCR? Have this one "repaired/cleaned"? I don't think it's inherent to the tape, as I do have a Sony RDR VX530 which has a more stable video output but with an electronic buzz in the audio.
I could probably capture the audio from one and the video from the other, and combine them in Adobe Premiere, but that's a last resort.
Please excuse any terms I've used incorrectly, and if a mod wants to move this thread somewhere more appropriate, have at it.
Thanks in advance for any insights.
Panasonic DMR-EZ48V clip - https://youtu.be/gProgUuNdLQ
Yikes! I have an EZ48V (PAL), admittedly brand new, but it is rock-solid on the tracking. It's TBC qualities are on the same level as the famed ES-15. In fact I often use it instead of the ES-15.
I suspect that yours needs some work, judging by the wobbly picture, although as RGR says, it could be the capture device. -
Capture device is El Gato (I know I know) but I don't think that's the issue as I've transferred some tapes and get some good results.
If it's a worn head, or the vcr needs work, what's my next move? Look for people who service vcr's locally? I'm in Chicago so I suspect I can find someone.
Thanks for the feedback btw. -
The new head is unlikely to be available. At least at a price that will be profitable.
It will probably be cheaper to look for a "new" VCR.
VHS-C tapes with no video
By SilverPT in forum Capturing and VCRReplies: 7Last Post: 26th Aug 2022, 09:47 -
Newbie need help with VHS-C tapes.
By feral107 in forum Capturing and VCRReplies: 2Last Post: 13th Aug 2022, 09:55 -
mouldy vhs tapes
By devdev in forum Capturing and VCRReplies: 2Last Post: 5th Feb 2022, 08:43 -
Dual VHS/VHS-C VCRs to play VHS-C tapes wthout adapter
By Bsmarado in forum RestorationReplies: 7Last Post: 18th Mar 2021, 06:04 -
which is the michael jordan or muhamad ali of the denoiser. :)
By frank_zappa in forum RestorationReplies: 3Last Post: 22nd Oct 2017, 23:40
