Hello, can someone convert this subtitle from mp4 format to srt?
Subtitle is being downloaded using ytdlp but in mp4 format, and it cannot be convert using subtitle edit.
https://cdvrjitp-playback.astro.com.my/dash-wv/cdvr/eid/1662105600-2700/rid-TID~2700~2...efault_ott.mpd)
This is the subtitle file if the mpd link cannot be access due to geolocation block. Thank you if anyone can help.
https://gofile.io/d/FRMLKi
This isnt only a srt subtitle file in a mp4 container, because the file is to big.
Check the mp4 with mediainfo to see what is into it.
Is there is a subtitle stream, it can be extracted with clever Ffmpeg-GUI.Last edited by ProWo; 24th Sep 2022 at 10:39.
I have give a try, but there is an error when converting it, this error show up object reference not set to an instance of an object in Mp4SubtitleParser by nilaoda
According to ye olde strings, this mp4 consists of a bunch of base64-encoded PNGs inside TTML. There's no way to turn this into a SubRip file without OCRing it yourself. I would go to the site itself and check the requests made to see if the site doesn't actually request its subtitles from a file with, you know, text content.
If you want the individual TTML files themselves from this MP4 then in a newly-made directory with the file runIf you add the ttml extension to one of the files greater than 1 KB and then open it with Subtitle Edit, it will ask you to OCR the text.Code:mp4box -raws 1 "rid-TID~2700~2022-09-02T08_59_00Z~2022-09-02T11_05_00Z__variant-default_ott [rid-TID~2700~2022-09-02T08_59_00Z~2022-09-02T11_05_00Z__variant-default_ott].eng.mp4"
However, given the command produces 626 files with actual subtitle content, this is kind of impractical to do. Not to mention you then need to join the results together afterwards. Finding something that can merge the XML files together might be a start though if you really want to go down this path.
Testing DaVinci Resolve on the cloud
By miguelmorin in forum EditingReplies: 4Last Post: 19th May 2021, 15:41 -
Rendering 'in the cloud'
By JayStew in forum EditingReplies: 2Last Post: 11th Dec 2020, 22:22 -
MSU Cloud Benchmark 2020
By DmitriyK in forum Latest Video NewsReplies: 0Last Post: 2nd Apr 2020, 10:23 -
Encoding Closed Caption / Subtitles Into a VHS Tape While Recording.
By dellsam34 in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2019, 23:11 -
Storing on cloud and live streaming
By sathyam in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Sep 2018, 06:51
