Hello, I'm using Videosubfinder, but it can't clean the subtitle images without any problems, and the lines are combined. The original subtitle is 2 lines. The program detects it as 1 line. Abbyy finereader program works properly, but video finder has a lot of settings. I'm waiting for your help
Post example of your video, cut few minutes sample. [don't re-encode]
Can you try the video here https://we.tl/t-aa4gHrel9c
Here is result of InpaintDelogo:
Extracted subs: https://we.tl/t-Jx9OaxHoUeCode:InpaintDelogo(Loc="60,750,-60,-16", Show=4, DynMask=4, DynTune=225, DynMask4H=90, KillBlobs=-4, KillNoise=5, DynMaskUp=2, Extract=1, ImgDir="D:\Imgs", ImgInflate=1)
Because you need more than few minutes to understand it, google for some guides.
InpaintDelogo is plugin for Avisynth+, AvsPmod is like GUI for Avisynth.
If you installed everything correctly then run the script example posted below in AvsPmod to extract subs [by "run" I meant preview the script, it's the triangle button at the bottom there]:
So, in "shoot a video" you would see me pasting the script from below and pressing that triangle.
PS:Code:LWLibAvVideoSource("D:\rickands04e03 (1).mkv") InpaintDelogo(Loc="60,750,-60,-16", Show=4, DynMask=4, DynTune=225, DynMask4H=90, KillBlobs=-4, KillNoise=5, DynMaskUp=2, Extract=1, ImgDir="D:\Imgs", ImgInflate=1)
You can find some info there: http://avisynth.nl/index.php/Main_Page
LWLibAvVideoSource() is filter from LSMASH plugin: https://github.com/HomeOfAviSynthPlusEvolution/L-SMASH-Works
PS2:
I recommend using Subtitle Edit's nOCR to do OCR instead of Abbyy Finereader.Last edited by VoodooFX; 25th Sep 2022 at 08:15.
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 00:39 -
Subtitles to extract
By ecolek in forum Video Streaming DownloadingReplies: 2Last Post: 14th Feb 2021, 05:45 -
Extract subtitles from mubi.com
By linuz in forum SubtitleReplies: 0Last Post: 9th Mar 2020, 14:37 -
How to extract subtitles from .ts file?
By vhwul62 in forum DVB / IPTVReplies: 27Last Post: 3rd Mar 2019, 20:24 -
How to extract Netflix subtitles
By ThePi7on in forum User guidesReplies: 1Last Post: 5th Dec 2017, 17:45
