ok, I have an avi file wich I want to make a mpeg. so i read this: http://www.vcdhelp.com/divxtovcd.htm and did exactly as was told. Now I have the mpeg wich when played only plays sound and plus, it's one GB. Maybe it's normal for it to be that bog of a file, but I don't know why it does'nt show the actual video. could someone help? thanx a lot.
If your AVI file was close to 100 minutes long, then 1GB would be normal for the VCD/MPEG-1 conversion (VCD is constant rate, 1124 kbit/sec video + 224 kbit/sec audio, roughly 10MB per minute).
As for not getting any video, does the file seem to play fine in, say, virtual dub "preview"? How about when you try "preview" in tmpgenc?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
