Hi guys...
I have a problem with a video and I don't know if the problem is in duplicate frames or other...
You can see the problem in the video:
https://drive.google.com/file/d/11eq6OgZsyBnd26YVgvbRU7924PaEq4yo/view?usp=sharing
These errors occurs in all the video, let me know if I can correct the entire video with a plugin or some other solution
I have tried filldrops and dedup but the problems remain, probably I am wrong on the problem. Let me know, thanks.
Results 1 to 14 of 14
Stepping thru the video you see a good rhythm of 59.94 unique frames per second, but at 130-131, 330-331 you see a jump;
the underlying frame is missing, it's not a duplicate issue.
Wait and see if you get any further suggestions -
Every 50 frames there are two dropped frames: (probably at 31, 32), 81, 82, 131, 132, 181, 182, 231, 232, 281, 282... 431, 432...
Smoother?Last edited by jagabo; 21st Sep 2022 at 23:17. Reason: added sample
Please can you give me the code line and the plugin to use?
I know this: SmoothD2
SmoothD2(quant=3, num_shift=3, Matrix=3, Qtype=1, ZW=1, ZWce=1, ZWlmDark=0, ZWlmBright=255, ncpu=4)
or
MipSmooth
MipSmooth(downsizer="lanczos", upsizer="bilinear", scalefactor=1.5, method="strong")
or
MSmooth
clip = core.msmoosh.MSmooth(clip, threshold=3.0, strength=1)
These are the default in Staxrip
I have tried these and the result is not the same as yours.
Please give me the name of the plugin and the line of code that you used, thanks.Last edited by salvo00786; 22nd Sep 2022 at 03:53.
First I used this "manual" script:
InsertFramesMC() adds a motion interpolated frame at the indicated position. Search these forums for it. You will have to manually add more for the full length video. And you'll need to work backwards as adding frames increases the frame number of the remaining frames.Code:LWLibavVideoSource("frame problems.mkv") InsertFramesMC(432) InsertFramesMC(431) InsertFramesMC(382) InsertFramesMC(381) InsertFramesMC(332) InsertFramesMC(331) InsertFramesMC(282) InsertFramesMC(281) InsertFramesMC(232) InsertFramesMC(231) InsertFramesMC(182) InsertFramesMC(181) InsertFramesMC(132) InsertFramesMC(131) InsertFramesMC(82) InsertFramesMC(81) InsertFramesMC(32) InsertFramesMC(31)
Another approach is to double the frame rate then use SelectEvery() to pick out the frames you want:
Here I used FrameRateConverter() to double the frame rate with motion interpolated frames between each of the original frames, then use SelectEvery() to select all the original frames (the even numbered frames after doubling) plus two motion interpolated frames (61 and 63). The benefit of using this method is that you don't have to go through the entire video and specify each interpolated frame. But it will fail if there is a change of cadence somewhere along the line.Code:LWLibavVideoSource("frame problems.mkv") FrameRateConverter(FrameDouble=true) SelectEvery(100, 0,2,4,6,8,10,12,14,16,18,\ 20,22,24,26,28,30,32,34,36,38,\ 40,42,44,46,48,50,52,54,56,58,\ 60,61,62,63,64,66,68,70,72,74,76,78,\ 80,82,84,86,88,90,92,94,96,98) -
Ok, the first method is a little problematic because the video has 318017 frames... I think that the problem is in the entire video.
1) How can I analyze the entire video and see where are all the problems? There are software or plugin for this or I have to use my eyes?
2) I used your second method on the same file, that I loaded here, but why my after encoding the framerate is not 59,94 but 62,34, probably because you used other two frames 61 and 63?
3) This is a pure example only to understand your workaround. For example if I convert the file from 59,94 to 23,76 (not the exact half), your code is valid or you have to use another code? If I understood correctly if I convert the file to 29.97 (half of the framerate), I have to add 31 and 33 instead of 61 and 63, but if for example I convert the file to 23.76???
Probably I have to add 25 and 27 in the code?
For example I converted the file to 23.76. The code is good or wrong for this file?
20,22,24,25,26,27,28,30,32,34,36,38,\
60,62,64,66,68,70,72,74,76,78,\
this is the 23.76 file
https://drive.google.com/file/d/11hxKdcPX7HcE8MMhAyIIU-hg_cs_vMeC/view?usp=sharing
4) This is another question, what is the difference between CAS and CASm?Last edited by salvo00786; 22nd Sep 2022 at 11:23.
You have to step through frame by frame looking for unexpected jumps in the motion. That can be hard to see in many shots. Since the pattern here is two frames in every 50 frames you can skip ahead by multiples of 50 frames and see if it's still consistent.
Since I added 2 frames to every group of 50 frames there are 4 percent more frames (52/50). If you want to keep the running time (to keep the audio in sync) you need to increase the frame rate proportionately. The alternative is to keep the frame rate at 59.94 (add AssumeFPS(60000,1001) at the end of the script) and lengthen the audio by 4 percent.
The frame rate and chosen frames I used was specifically to restore the missing frames halfway between 30 and 31, and 31 and 32, of every group of 50 frames of the of the original video.
If you decimate 60p to 24p you are removing 36 out of every 60 frames. The process for restoring those 36 frames will be very different.
I dont' even know what that is referring to! -
Here's how you restore 60p from a 60p video that has been decimated 24p.
Here I started with a 60p video (so we can compare the original 60p to the restored 60p) and decimated it to 24p. Between the frames of the 24p video there are sometimes one missing 60p frame (1/2 between the surrounding frames), sometimes two missing 60p frames (1/3 and 2/3 between the two surrounding frames), alternating between the two possibilities. To account for both possibilities we multiply the frame rate by 6 (24 * 6 = 144). Then we pick out the appropriate frames with SelectEvery().Code:LWlibavVideoSource("60p.mkv") # 60p source ShowFrameNumber(x=20, y=20) # number the frames so we can identify the original frames. dec = ChangeFPS(24000, 1001) # leaves frames: 0, 2, 5, 7, 10, 12, 15, 17... #return(dec) # if you want to verify the decimation interp = Interframe(dec, Tuning="weak", NewNum=144000, NewDen=1001, cores=4) # frame rate * 6 #return(interp) # if you want to see the 144 fps video SelectEvery(interp, 12, 0, 3, 6, 8, 10)
As you can see the final result is as smooth as the original video and has the same runtime. But you can tell some frames are interpolated by looking closely at the frame numbers and other interpolation artifacts.
Note that the SelectEvery pattern will be a little difference if your sequence starts with two missing frames rather than one. I'm sure you can figure that out...
The final result stacked below the original video: -
Keep in mind that the technique is specifically for 24p video that was decimated from a native 60p source. It is not for native 24p video (like movies) where successive frames originated at 24p intervals.
When starting with video that's already been decimated to 24p the script will look like:
I also removed the lines which were just informative. And the decimation pattern must be consistent over the entire video.Code:LWlibavVideoSource("24p.mkv") # a 24p video that has already been decimated from 60p interp = Interframe(dec, Tuning="weak", NewNum=144000, NewDen=1001, cores=4) # frame rate * 6 SelectEvery(interp, 12, 0, 3, 6, 8, 10)
And lastly, motion interpolation often doesn't work well. So don't be surprised if you see gross distortions in some shots.Last edited by jagabo; 24th Sep 2022 at 07:43.
Hi... A simple question. It's true that if my final upscale resolution is 1080p, I have to go over 1080p and after that downsize to 1080p or this is a metropolitan legend?
Removing all duplicate frames in a video clip
By ecortez in forum EditingReplies: 0Last Post: 10th Mar 2021, 21:23 -
Duplicate frames issue
By tupper in forum Video ConversionReplies: 1Last Post: 18th Dec 2019, 12:04 -
H.265 introducing duplicate frames
By ZetaStax in forum Video ConversionReplies: 22Last Post: 2nd Aug 2019, 15:58 -
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 17:43 -
Fix duplicate frames on old digicam video
By Homestar in forum RestorationReplies: 13Last Post: 25th Dec 2017, 01:15
