  1. Hi
    please respect for the cats
    Please consider this MXF source:
    https://www.dropbox.com/s/0tk8qjbfvirvjy4/C0004.MXF?dl=0
    simply I need to do a MOV in video stream copy using:
    ffmpeg -i c0004.mxf -vcodec copy -filter_complex "[0:1] [0:2] amerge" -filter_complex "[0:3] [0:4] amerge" -acodec pcm_s16le -ar 48000 -aspect 16:9 out.mov
    and in Edius and Premiere comparing the original C0004.MXF frame-to-frame with out.mov. Using Adobe premiere the out.mov result in a green screen and don't import.
    Edius import the out.mov but comparing frame-to-frame with original C0004.MXF is not the same. The total lengh is shorten than the .MXF, the first frame is different
    I wonder if is there a way to get a .mov (video stream copy) that is exactly the same as the mxf ?
    Feb 2006
    Originally Posted by marcorocchini View Post
    Hi
    try this here - https://stackoverflow.com/questions/55913188/using-ffmpeg-to-convert-mxf-fails
  3. Member Cornucopia's Avatar
    Since you have Edius and Premiere Pro, you can just import your MXF clips directly rather than having to convert them to something else first.
  4. Anonymous
    Guest
    Hi, thanks for the answer, it helps me too.
