Hi guys I have my several movie collection and I am using Handbrake so I can reduce the size but keeping the quality, I tried with an animated movie encoding x265 NV (with my Nvidia) with CRF 17 and there´s a big difference compare with original, so I get from another site the same movie already encoded and the video quality is amazing, because that I so wish to know what do you recommend? what maybe i´m doing wrong with Handbrake? what tool do you use for encode?
Thank you in advance
There a lot of options/selections in Handbrake and many other encoders. As to video not looking good, we could use some screenshots of your settings. Could be as simple as your bitrate is too low. Maybe upload a clip of the original video 15 - 30 seconds long. We can take a look.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Thank You How do you encode with 2 pass? how to calcule? and when I tried to encode the movie with x255 with proccesor tried with 2 PCs, Handbrake in 00.9% just freezes the I dont know if problem is the movie or somthing that I can fix on Handbrake?
Something that I notice the problem on animated movie is with Handbrake because I tried with ex Bdrebuilder and is amazing too, but I preffer Handbrake, is there´s any option for animate movie I so appreciate if you can tell me, I´m doing the encoders with my Nvidia because with proccesor takes more than day
If you just can tell me for animated movies maybe maybe there´s an option that I not see? -
Nobody here knows the quality of your source, nor the settings you used.
If you want further assistance post screenshots of all your settings tabs and a sample of the source, at least
30 seconds -
Every modern encoder and program can produce very good output with the right settings. Try x265 with CRF 17, animation tuning, slow or slower preset. Yes, it will be very slow.
2 recommendations: Tool for creating DivX and Tool for removing DVD menues
By schmutzbrust in forum Video ConversionReplies: 14Last Post: 24th Sep 2022, 21:04 -
Help for a recovery tool
By nifaf in forum Video ConversionReplies: 0Last Post: 3rd Jul 2021, 07:15 -
Tool for burn a BD disc?
By BlurayHD in forum Newbie / General discussionsReplies: 10Last Post: 3rd May 2021, 16:12 -
where is directshow codec tool
By agent222 in forum Authoring (DVD)Replies: 0Last Post: 10th Mar 2020, 16:13 -
Defrag tool?
By BlurayHD in forum Newbie / General discussionsReplies: 20Last Post: 5th Mar 2020, 14:43
