  1. Member anon125's Avatar
    Feb 2006
    Canada
    I used to have a slide right in old pinnacle but cannot find it in 25.
    Apr 2003
    If you are looking for the SLIDE RIGHT transition, it's still there in 25. Have you done a complete installation? Go to transitions in your library and use the search function to see if it shows up.
Name:	P25 Transitions.JPG
  3. Member anon125's Avatar
    Feb 2006
    Canada
    thanks
    i find the search engine does not work very well
    and if it says a transition is in favorites, favorites is empty!
    so i made another folder and put a couple of favorites in there.
    i will keep hunting for slide right!
    it is 25 ultimate.
    thanks
