[Attachment 66856 - Click to enlarge]
Is there any DVR model that serves to capture VHS? Would it be a good or bad idea?? @dellsam34
To me, not worth the expense of a DVR. You'd do far better with a good VHS capture to PC, then run it through avisynth or hybrid. I TIVO will run you $350-$500 usd. If you're worried about storing the captures, USB hard drives are cheap. If you want the best quality digital video, you will need to do the capture and deinteracing etc.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
You should check if it does NOT convert to 16:9 there are a lot of DVR or converters that do that, advantage is, it has a TBC effect you have to convert back to 4:3 ofcourse.
Don't know how much money you want to spent… most DVR's will have no TBC function, a Home Theatre, or DVD recorder as passthrough will help, and then an HDMI recorder,
cheap DVR's will capture straight to h264, for some more money you can record (HDMI recorder) to ProRes422LT,(Apple codec) or an AVID codec if you're on windows.
(Capturing with a PC will give you lots of problems, there are not a lot of good capture cards/devices for a pc, new stuff is trash, the few good ones can only be used on old operating systems, which in turn are slow because of that)
Time Base Correctors are rare and expensive, and were ony meant for pro equipment use, Try to find a Panasonic vcr/combo that has the "VHS fresh" feature, instead.
Onvif is a brand for security camera recorders,(the one in the picture has 4 channels) the signal of a vcr is not as stable as that of a camera.
these recorders capture directly in to a compressed format which makes it possible to directly store on a small HDD
capturing uncompressed needs fast and large drives, ProRes422LT/AVID is a frame by frame compression and is good enough for VHS, and lets you edit your footage in a good fashion.Last edited by Eric-jan; 19th Sep 2022 at 08:12.
Modern DVRs.. no.
Game capture cards.. no.
DVD/HDD recorders.. yes.Last edited by jwillis84; 19th Sep 2022 at 00:08.
How to set HCEnc for Interlaced VHS capture (or better encoder for VHS)
By Tek03 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2022, 20:58 -
Panasonic NV-DH2 Firewire VHS/D-VHS Capture Help
By ArianK in forum Capturing and VCRReplies: 6Last Post: 23rd Apr 2022, 15:29 -
Capture old VHS to PC- Why does the VHS playback look misaligned - pics
By jayleonois in forum Video ConversionReplies: 31Last Post: 9th Dec 2020, 13:32 -
Treating Panasonic DVR hard drives like VHS Tapes
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th May 2019, 23:57 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 19:50
