hi, I have this doubt since a while.
can I delay and audio track in mkvtoolnix by a fraction of a millisecond?
for example not 5, not 6, but 5.2 or 5.4?
is it possible? it accept integers only? comma and dot return errors..
how do I write it?
Results 1 to 9 of 9
Out of curiosity: What for?
is it possible?users currently on my ignore list: deadrats, Stears555, marcorocchini -
What am I not understanding here? To me, A/V sync always depends on at what moment you perceive image and sound. Ignoring speed of light, sound-speed travels at approx. 343 m/s. A tenth of a millisecond would mean a difference in distance of 34.3 mm, if I'm correct. So during real-life listening, your ears should stay in such exact range to be synced within that precision. Move your head and you're "off".
So, what do you mean with "visually perfect in sync"? And is there a way how to determine this, within a 0.1 ms (or any, for that matter) accuracy? -
@maudit: What tool would you use to check that delay? (to be frank I know of no tool which a. visualized such delays or b. is even that accurate)
Now that I think of it: one could adjust the a/v delay by manipulating the timecode file of the stream.
Also read https://www.matroska.org/technical/notes.html -> so it's possible, but you would have to manually edit the time stamps.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
I mean I open 2 vdub2 windows, I arrange them side by side, then I zoom in the audio wave display, and 1ms can be 10 or 20 pixels or so.
vdub2, thanks for that hint, I'll look at it, but for the moment I think I can just try to use
DelayAudio(clip, float seconds)
in case I need more precision. -
LOL, last I checked, neither VirtualDub nor VirtualDub2 always correctly read the delay correct.
iirc. then I used a mp4 container and reported possible issues to the gpac dev and the result was that the file was right, but neither VD version did display the delay properly, so I would not reply on that visualization too much. (especially with anything other than wav audio)users currently on my ignore list: deadrats, Stears555, marcorocchini -
I have no doubts that vdub2 could sometimes visualize the wave in an uncorrect position, with certain files/audio types.
that's why I usually recheck it by refreshing, re-selecting the audio track.
but for most of the cases it works properly, the sync is correct and if for example I add 1ms in toolnix or in the script,
the vdub2 wave audio display, correctly moves by 1ms.
I sometimes double check it too by using avisynth+ waveform command in avspmod,
and I didn't notice any discrepancies since now, except maybe very few cases. -
the vdub2 wave audio display, correctly moves by 1ms.users currently on my ignore list: deadrats, Stears555, marcorocchini
Mkvtoolnix
By fits79 in forum Video ConversionReplies: 11Last Post: 28th Jul 2022, 11:24 -
mkvtoolnix
By vega69-ux in forum EditingReplies: 3Last Post: 25th Sep 2020, 19:54 -
How do you add an audio delay in mkvtoolnix?.
By Felow in forum Newbie / General discussionsReplies: 6Last Post: 18th Sep 2020, 17:31 -
help with mkvtoolnix and negative delay
By vangeliis in forum EditingReplies: 14Last Post: 14th Feb 2020, 11:10 -
about MKVToolNix
By ujang in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2018, 22:32
