Hello
I'm looking for an easy/good DivX creation tool:
I wanna create DivX files for a DVD Player. It supports
DivX: 3, 4, 5, 6
Video-Resolution: 720 x 480 @ 30 fps; 720 x 576 @ 25fps
Bit-Rate: 4000 kbps; Peak max. 10.000 kbps; MPEG 4 ASP Level 5
I know it's a bit out of date, but do you can recommend something?
I'm also looking for an easy way to get rid of DVD menues from already ripped DVDs. I have some on my hard disk.
Is there a quick way to load the "dvds" in a program and just remove the menues? (creating new ifo etc.)
Thanks for your attention, and excuse my english (not my native language)
Results 1 to 15 of 15
Easiest tool to make a Main-movie-only DVD: DVD Shrink
You don't have to actually shrink, just select the movie PGC to keep. And you should be able to select a directory as source. -
Be careful what you wish for. As stated, you can create a main movie only dvd but what about audio selection, sub-titles etc. No menu = no choice. And menus actually take very little space on the actual disk. Been a long time since I used dvd shrink but if memory serves you can choose what to keep audio etc. wise.
If you want to create Divx from dvd sources then the classic program is Gordian Knot or the simpler version of this AutoGK. The bitrates you quote appear rather excessive for Divx but, I guess, the dvd player requires these. Even so, those bitrates are perfectly adequate for Mpeg2 which your player should also support. -
I don't get it.
"I have dvd rips".
"I have a dvd player".
You want to play files that are a generation worse quality because...you don't want to make a disc, or use a different (general media) player?
Scott -
Thanks to all...
The DVDs already have only one language and no subs so there is no menue needed.
@Scott
is the quality loss that high? The problem is the video files are too large for a single dvd (even dual layer, 5 hours and more). So i thought i can fix this, using divx. -
As I previoulsy inferred, not at the bitrates you quote (even if the dvd player requires them)
Some simple maths:
2 hours single-sided dvd @ 4000 kbps for video
4 hours double-sided dvd @ 4000 kbps for video
Yes. You can go lower but quality will soon suffer
DivX does allow you to reduce bitrate significantly but quality was never great to start with. But if you need 4000 kbps you will still have a file approaching 10 gb for video alone @ 5 hours
And do you really need a single dvd to be 5 hours ? -
Sorry for the delay... Maybe it helps to explain, what i really want to achieve...
I'm looking for a way to bring video files back to VHS. I already tried a lot (couple media boxes like Icy Box etc.) But nothing worked satisfactory. :/
I need RGB Scart (here in europe) for best video quality, but all my tested solutions offer only composite (or HDMI wich want work on an old VCR)
So i thought a DVD Player could work, because the european devices output RGB Scart. But problem is, these players don't support many codecs (mostly only divx or xvid)
And devices with USB won't support HDD Drives or bigger USB sticks (at least the devices i tested)
So maybe someone knows a better approach...
A device that outputs RGB Scart and supports USB devices and many video codecs. Maybe a raspberry pie could so this? I saw some analog video output addons lately...
Thanks -
"video files back to vhs"
Video FILES never were on vhs. Vhs is an analog medium.
If you are attempting to use a vcr to store video files, understand that unlike optical DISCS, tapes like vhs are an "unstable" medium. Unstable media require proper stream formatting and greater error correction to avoid or alleviate error related issues.
That was one of the main points behind the creation of the Mpeg Transport stream format. But this comes at a cost of greater overhead. Divx files have no such resiliency in the form you are looking at.
As a person who lived through the whole lifespan of vhs' rise, fall, and demise, I remember well the reasons everyone wanted to move away from it.
"...she wouldn't have believed me. She had to learn it for herself."
Smh
Scott -
Maybe Scott has already adressed this but, having already replied once, I will add my two cents..
ANY codec is a digital conversion from either an original analogue form or another digital form. VHS is (was) an analogue form- analogue knows zilch about codecs. So you can output via a dvd-player to a VHS recorder and save that video to VHS - codecs do NOT come in to the arguement. At a 'push' you can even transfer what you see on your PC since that is now digital back to VHS.
In a word or three your whole topic clouded the issue and wasted the time of those who initially replied. -
A "DVD Player" plays "DVD Video discs". If it plays anything else in addition, I would not call them only "DVD Players" anymore...
Furthermoer I see no good reason to still record VHS tapes in these days. Who would still like to handle this quality loss? -
You want to record to VHS? Then even more so, split your videos and play them. To get a 5 hour VHS recording, you'd need to record at EP/SLP with severely lower quality.
Why do you need your video on VHS? Is is for artistic reasons? If [so], you won't get a true representation of VHS quality because your reencoded video will have digital artifacts.
The analog output hole has been closed on all current playback devices including the Raspberry Pi.
I'm sure someone will correct me if I'm wrong, but VHS (and all analog tape formats) is native YUV , so outputting to RGB requires a conversion and will result in lower quality. The best quality you'll get from VHS is through S-Video or possibly component?Last edited by lingyi; 24th Sep 2022 at 21:11.
Command line tool to extract subtitle from DVD?
By Selur in forum MacReplies: 1Last Post: 12th Sep 2021, 18:03 -
Help for a recovery tool
By nifaf in forum Video ConversionReplies: 0Last Post: 3rd Jul 2021, 07:15 -
UHD-BD Authoring Tool
By SameSelf in forum Authoring (Blu-ray)Replies: 142Last Post: 16th Dec 2020, 22:14 -
Defrag tool?
By BlurayHD in forum Newbie / General discussionsReplies: 20Last Post: 5th Mar 2020, 14:43 -
Recommendations for a free, lossless video trimming tool?
By rowjekto in forum EditingReplies: 2Last Post: 14th Apr 2018, 19:57
