i formatted my computer and decided to install the new nero 5.5.24 software it seems to work fine till i try to watch it in my pioneer dv37 player. all i get is a blue screen.i have searched for tracks using the random button with no luck. all my earlier disks recorded with nero 5 work fine. if i use computer software and load the dat file from the recorded cd it plays fine. i have tried 5.5.24, 5.5,5.0 all with no luck. the coasters are adding up.
at first i thought it might be the menu selection so i turned that off, even though the backround picture comes up fine on the dvd player. i figure i am missing something but just don't know what.
windows me
800mhz intel cpu
324 megs ram
plextor 12x eide recorder
asus cusl2 motherboard
<font size=-1>[ This Message was edited by: robot1 on 2001-07-01 14:17:23 ]</font>
Insert the VCD and don't just press PLAY.
Let the DVD find out that there is a VCD inside. If the player shows up VCD then click "1" or the "skip forward" button.
It looks like a bug that came in with NERO 5.5.24 and even uninstalling NERO (and even deleting all ahead registry keys) and installing a downlevel version won't help.
Same problem over here
Recorded DVD picture jumps, original VHS source doesn't
By bigj7489 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 08:09 -
By bigj7489 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 25th Jun 2010, 19:59 -
Video recorded with a Digital Photo improvement of the picture
By shorto in forum Video ConversionReplies: 8Last Post: 10th Jun 2010, 10:31 -
Old VHS Tapes Have No Picture Recorded at LP and SLP Speed
By Hypnotised16 in forum MediaReplies: 14Last Post: 17th Mar 2010, 15:09 -
How to remove black side panels from a 4:3 picture recorded as 16:9
By topcat55 in forum Video ConversionReplies: 3Last Post: 14th Oct 2008, 00:56
