I have some TFF interlaced videos. I have used Adobe Media Encoder in the past to encode via MBAFF and was wondering if Handbrake can do the same. I tried entering MBAFF in the advanced options area on the video tab but it does not seem to work. Are there special commands to do this? I had also tried TFF:MBAFF but the resulting video is still progressive and not MBAFF, according to MediaInfo.
Any thoughts?
Cheers
Results 1 to 10 of 10
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
Thanks. That caused Handbrake to stop in error. However, interlace=tff did not. No effect though. It still encoded interlaced as progressive. I also tried interlace=tff:MBAFF but that didn't do anything either.
Maybe Handbrake does not permit this?'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Actually the option you need is just tff (or bff as the case may be) and it will do MBAFF.
Of note is that you need to ensure the height of the video is divisible by 4 for this to work. If it isn't then Handbrake will error out with error:
In this case by removing adding back the automatic crop to 720x480 it runs fine. If the tff (or bff) option is not present then this error will not happen.x264 [error]: height not divisible by 4 (720x478)
Any idea why?'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Problem with FFmpeg while converting interlaced videos using MBAFF
By FFtvuser in forum Video ConversionReplies: 5Last Post: 19th Jan 2022, 05:45 -
Problem re-encoding MBAFF
By mugz8391 in forum Video ConversionReplies: 9Last Post: 26th Mar 2021, 21:29 -
Mark/Force MBAFF Encoded Video as Progressive
By ajingo in forum Video ConversionReplies: 7Last Post: 22nd Feb 2021, 06:24 -
Handbrake
By chris42773 in forum RestorationReplies: 0Last Post: 28th Apr 2019, 01:26 -
Problems Deinterlacing - MBAFF - Separate Fields - Variable Framerate?
By danfgtn in forum Newbie / General discussionsReplies: 4Last Post: 12th May 2018, 19:31
