I've now used the Alphacephei models in Subtitle Edit a few times. There's no contact info I've seen where I could know when those models are updated and processing voice better. I'm using the vosk routine in SE pretty much just to get the timings of the speech and then doing all the corrections line by line. That's alright; it keeps me from being frustrated by You Tube Creator routines that fail to function. (I had one just stop on me today at minute 6.)
Who knows what the release notifications might be for the vosk models?
The Alpha cephei models in Subtitle Edit - they can be a real lifesaver, right? As for updates, I'm in the same boat - it's a bit tricky to keep tabs on when those models get a boost. I've been relying on the vosk routine in SE for timing too, and hey, at least it's keeping our frustration levels in check compared to those wonky YouTube Creator routines!
Thanks for the reply. I never got You Tube Creator to work consistently at all. I even made screen shots of each step. Regardless,
it would look like it was writing the sub and then nothing. But output was pretty good the one lucky stroke I had. I'm hand correcting now with a printed play text since the content is historic.
No doubt SE would be first in knowing about releases for updates. As I understand it there are multiple programmers or developers for it.
Whisper AI is an alternative also in SE. Many swear by their install of that through Python programming. But Whisper fails often in SE-- seems like after it has run awhile, if that makes any sense. I'm no Python programmer so I have not been able to do the command line things needed. -
I just came across your post and I totally feel you on the whole Alpha cephei models and vosk routine situation! Honestly, I'm just dipping my toes into the vast sea of machine learning myself, so I'm not exactly the go-to guru on updates. But hey, I've actually started exploring the realm of machine learning recently. I found this goldmine of training courses at selectcourses.com that I'm itching to dive into. Planning to grasp the basics, wrap my head around those algorithms, and see how machine learning spices up real-life processes and projects. Who knows, maybe this could even steer me into a whole new career path!
VOSK link
https://alphacephei.com/vosk/models
There is a contact section on this page if you want to contact them about anything.
I was excited at first about Vosk, but then I discovered Whisper AI and never looked back at Vosk.
But to get the best out of Whisper, you need a really good PC and a GPU of 8GB VRAM.
Favorite VSGAN models ?
By Selur in forum Video ConversionReplies: 0Last Post: 20th Aug 2022, 09:19 -
YT-DLP Learning To Batch Download
By Tom Saurus in forum Video Streaming DownloadingReplies: 23Last Post: 16th Jul 2022, 14:36 -
Learning Platform
By timonndpumbaa in forum Video Streaming DownloadingReplies: 3Last Post: 25th Jan 2022, 07:58 -
Learning ffmpeg
By dellsam34 in forum Video ConversionReplies: 17Last Post: 3rd Jan 2019, 15:48 -
Trying to decide which editor to try learning with
By nopEda in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2018, 16:19
