Results 1 to 30 of 36
  1. Hello, while I am waiting for my access to getwvkeys to be approved on Discord, please can someone kindly provide the key for this URL:
    https://www.channel4.com/programmes/grease/on-demand/42653-001
    Many thanks
    Feb 2022
    Search the forum first!
    --key 587ee28c0a27a7da3cfdb43604013bcc:d81b6445425c0e00e 574adf13cece4e8
  3. Thank you so much ! I am trying to use mp4decrypt with the key but it doesn't appear to be working. Do I need to be using something else for the mp4 and m4a files like a Key ID ?
    Feb 2022
    The space is an artifact from somewhere and shouldn't be there. Same key for both streams.
    just checked my original post and tried to edit out the space - it wasn't there. So this crappy outdated vBulletin that the site owner uses inserted it for free!
  5. Thank you very much. I tried without the space but cannot get ffmpeg to work at the end, it keeps saying:
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0000016e7996d080] Incorrect number of samples in encryption info
    gv_dec.mp4: Invalid data found when processing input
    [mov,mp4,m4a,3gp,3g2,mj2 @ 0000016e7c8df0c0] Incorrect number of samples in encryption info
    ga_dec.mp4: Invalid data found when processing input
    Is this the right sequence of events I am using?
    mp4decrypt --key 587ee28c0a27a7da3cfdb43604013bcc:d81b6445425c0e00e 574adf13cece4e8 gv.mp4 gv_dec.mp4
    mp4decrypt --key 587ee28c0a27a7da3cfdb43604013bcc:d81b6445425c0e00e 574adf13cece4e8 ga.m4a ga_dec.mp4
    ffmpeg -i gv_dec.mp4 -i ga_dec.mp4 -c copy final.mp4
    The space is also present on my post and I cannot also seem to edit it out!
    Feb 2022
    can you play the unencrypted streams individually? vlc gv_dec.mp4 for instance?
    for ffmpeg I usually ffmpeg -i audio.m4a -i video.mp4 -acodec copy -vcodec copy output.mp4 But I can see much difference with general copy command.
    I'm just wondering, my stream urls are from the channel4 app and maybe a different key from desktop urls?? But the VLC check will tell you.
    I've just download it and it plays for me screen height is 576 not too good if you were expecting 1080.
  7. try this
    587ee28c0a27a7da3cfdb43604013bcc:d81b6445425c0e00e574adf13cece4e8
    when you set a number greater than 50 characters, the forum automatically add a space
    to work around this you must enter the value in the code tag
  8. I tried playing the gv_dec.mp4 file on VLC and it shows the length of the file but nothing is displayed on the screen. I was expecting the video only to be displayed without the audio but I get nothing. Is there any way you can get the desktop key please as they might be different ?
  9. interesting thanks for checking. Have I done this correctly? I first downloaded the mpd file as follows:
    ytdlp.exe --allow-u --downloader aria2c -f bv,ba "mpd link"
    then I used the 2 mp4decrypt commands with your key. Is there something I have done incorrectly ?
  10. Correct key for decryption
    00000000000000000000000004613673:5d0018593977fcf3471a9db28b35fb57
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
    Feb 2022
    OK my mistake then. Sorry. But we now know chan4 app keys and desktop keys are different.
    @lomero Thanks for the [code] tip
  12. Thank you that worked ! Only problem now is that I appear to have downloaded the audio description track instead of the non-audio description track. How can I download the non-audio description track please from the mpd file ?
  13. yt-dlp -F link ---- and you have a full list available
    yt-dlp -f xxx link --- use this when you have choice your download track (replace xx with right value)
    here your full list
    [Attachment 66668 - Click to enlarge]
    so, run like example yt-dlp --allow-u -f audio_eng=128000 "https://mpd" to download audio only eng format
  14. Well, there are 2 audio tracks, dunno which one's which so you can download them like this
    ytdlp.exe --allow-u -f audio=128000 "mpd"
    ytdlp.exe --allow-u -f audio_eng=128000 "mpd"
    click click2
    Feb 2022
    I use worst audio -- yt-dlp --allow-u -f wa ...etc etc thats the first one in the list. Yt-dlp selects the best ie. the lowest list order for the download unless overridden.
  16. I tried that option but it returns this:
    [generic] stream.mpd?c3: Requesting header
    WARNING: [generic] Falling back on generic information extractor.
    [generic] stream.mpd?c3: Downloading webpage
    [generic] stream.mpd?c3: Extracting information
    ERROR: [generic] stream.mpd?c3: This video is DRM protected
  17. "This video is DRM protected" is only returned when you don't use --allow-u
    click click2
  18. Member
    Feb 2022
    removed
    Oct 2022
    Hi, I'm a newbie, I don't know anything about coding.
    Can you make a video showing me how to get channel4.com key?
    I watched a video on how to get your Player.pl key. And I got the key successfully.
    But that doesn't apply to channel4.com. Please help me.
    I can watch your videos and follow along.
    Oct 2022
  21. Originally Posted by mrbin9x View Post
    Yeah, that would be you doing the equal part
    click click2
  22. Member
    Oct 2022
    Thank you so much.
    Looking forward to your help.
    Waiting for your video tutorials.
  23. Member
    Dec 2020
    Croatia
    Thank you so much.
    I think he was being sarcastic lol
    I have a video showing how to get channel4 keys made by someone (maybe even vegeta) that I downloaded some time ago, but I haven't tried it yet since I don't have a VPN:
    https://userscloud.com/krbtlgquywpd
    good luck
  24. Yeah, that's not me. I'm not doing webms. I'm doing glorious master race mp4 or mkv.
    I remember that video too, maybe it was pkp? Not sure either. We already forgot that hero... he deserves better.
    click click2
  25. Member
    Oct 2022
    Thank you so much.
    good luck
    Thank you so much!
    I tried but got this error.
    [Attachment 67058 - Click to enlarge]
    I'm trying to get this series.
    https://www.channel4.com/programmes/gogglebox/on-demand/73371-002
    LICENCE
    https://c4.eme.lp.aws.redbeemedia.com/wvlicenceproxy-service/widevine/acquire
    Pssh
    AAAA7e+LqXnWSs6jyCfc1R0h7QAAAEYIARIQAAAAAAAAAAAAAA AABGg0mBoIcmJtY2g0dHYiJDAwMDAwMDAwLTAwMDAtMDAwMC0w MDAwLTAwMDAwNDY4MzQ5ODIA
    payload.py
    [Attachment 67059 - Click to enlarge]
    Please tell me where did I go wrong?
  26. Member
    Oct 2022
    I want to say thank you very much. <3
    I watched your video tutorial to get the key player.pl.
    I followed the video instructions and got the key.
  27. Originally Posted by mrbin9x View Post
    that script is old and doesnt work anymore. you need to get the latest one from getwvkeys discord
  28. Member
    Dec 2020
    Croatia
    if you don't get the one on discord, you can try the method from this thread (Diazole's downloader):
    https://forum.videohelp.com/threads/407144-Help-with-Channel-4-Key-to-this-programme-a...-method-please
    I don't have a VPN right now so I don't know if it works
  29. Member
    Oct 2022
    Can you send me the current script you are using?
    Thank you very much!
