Hi
and however
I'm inside a batch where I get the video duration in a string called %aviGenDuration%
for example the result is:Code:FFProbe.exe -loglevel fatal -show_entries format=duration -of csv="p=0" -sexagesimal "%~nx1.ts">aviGenDuration.txt set /p aviGenDuration=<aviGenDuration.txt
I wonder how can I do a mathematical subtraction so that the result is 4 millisecond less than the result. In this case the final result have to beCode:0:01:30.680000
is there a way? thanksCode:0:01:30.640000
You must parse it into its elements, convert from string to numerical, build it up into one figure of the smallest element, do the math, convert back to string, then re-separate into segments with delimiters re-added in. DONE.
Scott -
This is the clearest example I've found.
https://stackoverflow.com/questions/605522/print-time-in-a-batch-file-milliseconds
Unfortunately it's only precise to 2 decimal places. It should be pretty easy to modify to 3 (or more).Code:@echo off setlocal rem The format of %TIME% is HH:MM:SS,CS for example 23:59:59,99 set STARTTIME=%TIME% rem here begins the command you want to measure dir /s > nul rem here ends the command you want to measure set ENDTIME=%TIME% rem output as time echo STARTTIME: %STARTTIME% echo ENDTIME: %ENDTIME% rem convert STARTTIME and ENDTIME to centiseconds set /A STARTTIME=(1%STARTTIME:~0,2%-100)*360000 + (1%STARTTIME:~3,2%-100)*6000 + (1%STARTTIME:~6,2%-100)*100 + (1%STARTTIME:~9,2%-100) set /A ENDTIME=(1%ENDTIME:~0,2%-100)*360000 + (1%ENDTIME:~3,2%-100)*6000 + (1%ENDTIME:~6,2%-100)*100 + (1%ENDTIME:~9,2%-100) rem calculating the duratyion is easy set /A DURATION=%ENDTIME%-%STARTTIME% rem we might have measured the time inbetween days if %ENDTIME% LSS %STARTTIME% set set /A DURATION=%STARTTIME%-%ENDTIME% rem now break the centiseconds down to hors, minutes, seconds and the remaining centiseconds set /A DURATIONH=%DURATION% / 360000 set /A DURATIONM=(%DURATION% - %DURATIONH%*360000) / 6000 set /A DURATIONS=(%DURATION% - %DURATIONH%*360000 - %DURATIONM%*6000) / 100 set /A DURATIONHS=(%DURATION% - %DURATIONH%*360000 - %DURATIONM%*6000 - %DURATIONS%*100) rem some formatting if %DURATIONH% LSS 10 set DURATIONH=0%DURATIONH% if %DURATIONM% LSS 10 set DURATIONM=0%DURATIONM% if %DURATIONS% LSS 10 set DURATIONS=0%DURATIONS% if %DURATIONHS% LSS 10 set DURATIONHS=0%DURATIONHS% rem outputing echo STARTTIME: %STARTTIME% centiseconds echo ENDTIME: %ENDTIME% centiseconds echo DURATION: %DURATION% in centiseconds echo %DURATIONH%:%DURATIONM%:%DURATIONS%,%DURATIONHS% endlocal goto :EOF
interesting ***
but maybe my specific question is well explained here:
https://forum.videohelp.com/threads/406954-How-to-get-the-wav-pcm_s16-from-this-mp4
thanks -
No clearer than the original question, both of which have been answered multiple times (by me, genericly, and by jack_666 and jagabo specificly).
FFmpeg Batch for Windows
By Eibol in forum Video ConversionReplies: 812Last Post: 22nd Nov 2025, 13:33 -
comskip batch
By lj01 in forum Newbie / General discussionsReplies: 8Last Post: 29th Oct 2020, 16:25 -
how to use ffmpeg in batch?
By ujang in forum ProgrammingReplies: 14Last Post: 13th Apr 2019, 20:21 -
Batch Cropping in handbrake?
By RBCC in forum EditingReplies: 3Last Post: 15th Mar 2018, 18:52 -
Handbrake batch nobs
By RBCC in forum EditingReplies: 3Last Post: 19th Dec 2017, 06:20
