hi, what is the most reliable way to OCR some hardsubs and create an srt file nowadays?
InpaintDelogo + Subtitle Edit's nOCR or binary comparison.
oh, ok I see..
I read:
# Can be used to remove hardcoded subtitles or extract them to images for OCR.
Subtitle extractor default parameters:
SubsMask2Img( ImgDir="", CorrTh=0.8, SubTune=210, SubMinDur=12, SubSuspect=0, ImgType="png", ImgInflate=0, ImgInvert=0, ImgSize=1 )
SubsMask2Img: New option to extract raw non-binarized images.
# Enabled by "Extract=2" in InpaintDelogo() or "Raw" in SubsMask2Img().
New: "Extract" parameter to extract subtitles to images for OCR.
I'll try to read and understand it, sooner or later
thanks. -
You can't remove hardcoded subtitles,just extracting them is all you can do.
Those are just pictures,it would take too long to remove them with logos that constantly change.
Those are screenshots from the videos.
What that means?
To same effect I can say that it's 100000 times faster than what they are doing with AI upscalers, and 100 times faster than some deinterlacing or noise removal.
Actually it's opposite, with static constant logo you need to process all frames, when subs are only in some frames.
Here is a high quality example of hardsubs removal:
Before:
After:
Adding 1 srt as a hardsub to multiple video
By Glory Feel in forum Newbie / General discussionsReplies: 10Last Post: 10th Aug 2022, 00:41 -
Are there any programs that can give me detailed info about .srt files?
By pastwo in forum SubtitleReplies: 0Last Post: 26th Dec 2021, 03:11 -
Options to hardsub aegisub files
By diana0325 in forum SubtitleReplies: 1Last Post: 6th Feb 2021, 03:34 -
Hardsub Timing for SRT subtitle
By sunny in forum SubtitleReplies: 1Last Post: 10th Feb 2018, 08:09 -
ffmpeg watermakr+hardsub
By vl4d in forum Video ConversionReplies: 3Last Post: 7th Feb 2018, 02:33
