I am using Ubunutu 22. I would like to transfer audio from vhs tape A to tape B and sync the audio from A to the video motion on tape B. Both of these have been captured as mp4s. Any simple tools for this ? (So B will have new audio from A) Thanks.
use ffmpeg -- extract audio from tape A with ffmpeg -i input-video.mp4 -vn -acodec copy output-audio.aac
remove audio from tape B with ffmpeg -i tape B.mp4 -c copy -an out.mp4
add the new audio to tape B with ffmpeg -i input.mp4 -i input.aac -c copy -map 0:v:0 -map 1:a:0 output.mp4 -
This looks helpful. Thanks for the instructions. I am just wondering how I would know how much offset there might be to correct for to get the two sources in sync. So if one is 5 milliseconds behind the other, how would I know that value? Trial and error maybe? I will be trying this.
Can I get the hi-fi stereo audio from a PAL VHS tape in an NTSC player?
By ItaloFan in forum AudioReplies: 6Last Post: 18th Aug 2022, 21:52 -
Help Figuring out Problem with Audio on VHS Tape
By battybarney in forum Capturing and VCRReplies: 22Last Post: 4th Nov 2020, 19:29 -
please list the virtualdub filters to remove vhs tape video noise
By perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 13:45 -
Is a UK PAL video tape compatible with a continental Europe PAL VHS/S-VHS p
By arjaydavis in forum Capturing and VCRReplies: 7Last Post: 21st May 2019, 04:38 -
vhs tape question, 1/2 tape is fine and 1/2 way thru gets lines
By tomthetank in forum Newbie / General discussionsReplies: 8Last Post: 13th Jan 2019, 08:14
