This is the scenario (perhaps it could go into the newbie conversion forum?):
I have an ATI AIW Rage capture card. I have the Ligos LSX 3.5 mpeg-1 and mpeg-2 encoder. I have Adobe Premier 6.0. I desire to capture from VHS and convert to mpeg-2 to put onto VCD.
The issues:
The ATI card captures the files too darn big to put an hour of show on a 80 minute CD. So I figure I will get Adobe Premier to convert the files. I realize too late that Premier is not an encoder. So I grab the LSX and see that I will finally be able to encode the the captured files to mpeg-2. But, the files that ATI captures are not AVI. The three character extension is .mp2. I don't know what that is, but it appears to be specific to ATI. The Ligos LSX will not support this .mp2 crap. Niether will Premier. So, I get this idea. I will capture through Premier, which captures the video in AVI. But, somehow, once the file gets to big, I think over 2GB, then the AVI file won't play or be supported in ANY video player or encoder. This has something to do with Premier.
So, I have these problems. Any help?
Thanks,
Allan
The .mp2 is mpeg 2, just change file extention to .mpg
May the force be with you. -
First - yes, mp2 is MPEG2 but ATI adds padding to the stream and many progs will not deal with it. You need to change the capture type to AVI in MMC, but you also need to be aware that unless your hard drive is NTFS partitioned, you will run into the 4-gig filesize limit (some programs impose a 2-gig AVI limit). So you need to segment the AVI, which will work for most encoders. The other thing you need to know is that if you are making VCD, you should encode to mpeg-1, not mpeg-2. And finally, while premiere is great for editing, TMPGenc or CCE is better for encoding, for mpeg-1 only some like the Panasonic encoder.
The last thing you need to know is that ALL of these questions have answers present in the forums, probably within the last 30 days. Do some more reading.
A strange security scenario...
By davexnet in forum ComputerReplies: 7Last Post: 9th Feb 2012, 20:06 -
Codec Explanation, which is best for this scenario ...
By andrewbutkus in forum Video ConversionReplies: 30Last Post: 1st Sep 2010, 11:15 -
Unusual Scenario for DV capturing of Self Recorded VHS
By jcpost62 in forum Capturing and VCRReplies: 7Last Post: 15th May 2009, 12:29 -
which scenario gives a higher quality video?
By graysky in forum DVD RippingReplies: 19Last Post: 3rd Sep 2007, 11:40 -
Bizarre VERY Slow AVI Render Scenario
By maxtrack in forum Newbie / General discussionsReplies: 15Last Post: 6th Aug 2007, 18:18
