What are best settings to convert firewire-captured DV (miniDV camcorder) to mpeg2 (ntsc SVCD) using TMPGenc or Ligos? I am getting a low quality "graininess" (especially with faces) using the standard template settings for SVCD. Interestingly, the quality of the converted mpeg2 (using TMPGenc SCVD template) is very good if I just do an analog capture (VirtDub, Huffyuv) from the digital camcorder.
Thank you one and all.
myloula
Results 1 to 1 of 1
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 17:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 13:03
