Does anyone capture with WinDVR and are you having any good results.
I use WinDVR, but I dont do much capturing with it. Mainly due to my unhappiness with the quality of the captures.
On my system the highest size I can capture is 352x480. I have experimented with the 3 basic settings as well the optional settings and even created my own. I have found that unless I have a extremely good broadcast channel (dont have many), the captures are very noisy. My "good" channels produced good results on the capture. Also another hang-up with WinDVR on my system, is that all my channels have a green-ish hue that is not correctable. So my captures also have this green tone on everything. I have told WinDVR about this problem and asked them to add the ability to adjust the hue setting up or down in future versions.
Hope this helps.
Intervideo WinDVR 3 wont record more than 10 minutes
By goshtin in forum Capturing and VCRReplies: 1Last Post: 8th Feb 2012, 15:11 -
About windvr and easygrabber 2.0 capture.
By MidnightMike in forum Video Streaming DownloadingReplies: 3Last Post: 15th Dec 2010, 18:32 -
windvr 3 and no sound
By goodtilltomorrow in forum Capturing and VCRReplies: 6Last Post: 12th Oct 2008, 17:34 -
InterVideo WinDVR 3: "The specified capture format is not supported on
By SignedupGuest in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2008, 20:01 -
WinDVR Input disappears while recording
By jacx3 in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2008, 12:39
