Hello,
I'll try and be specific because i know very little about this.
First, are televisions PAL? or is it just the broadcasts and/or players (VCR,DVD) that are considered PAL? Not sure how that works.
Then, if PAL is apart of the television, would plugging it into an outlet in America show a picture at 625 lines instead of the 525? I know there are European plug adapter for general electronics, would this work in use with a CRT television?
Lastly, if all of that does work, what problems may arise? I think differently rated power supplies are something, I just don't know what. So this is where I'll stop because again, I know little about this subject and was hoping for some help answering them.
These questions comes from me wanting to know if buying a pal VCR and television would work in my home like it would in a home in Europe.
Thank you all for your time.
You'll have to check the voltage requirements of the equipment; you may need some kind of power transformer.
Usually PAL stuff would run at 240v 50Hz a/c Vs. the 120v 60Hz a/c returned from the the typical household power in the USA
using 240 volts in North America
By Skaperen in forum Off topicReplies: 0Last Post: 15th Jun 2022, 02:20 -
Are European Dubs done in PAL?
By Emilius123 in forum Newbie / General discussionsReplies: 17Last Post: 13th Jul 2021, 13:43 -
Audio Volume From Receiver Is Low When VCR Is Plugged In?
By companda in forum AudioReplies: 1Last Post: 7th Apr 2021, 15:32 -
NTSC DVD on a European PC?
By VenusAndMars in forum Software PlayingReplies: 6Last Post: 4th Oct 2018, 02:57 -
Proper Care for External Hard Drive plugged into a MINIX NEO U9-H
By CaptainCatholic587 in forum Media Center PC / MediaCentersReplies: 8Last Post: 5th Sep 2018, 07:22
