Hi... I have other two questions.
1) I have various videos that after downsizing create bandings problems. In Staxrip is better to deband and after that downsize or downsize and deband? Same queston for deblock, is better do deblock before or after downsize? What is the better downsizer for avoid Banding problems. I have tried Lanczos and banding problems occurs. Now I will try Spline64
2) In Staxrip I use ffmpeg PRORES / MOV.
In Encoder options, under Decoder, I use Avisynth/Vapoursynth. Obviously using NVIDIA, is faster with my graphics card, but for example I have seen that If I use Nvidia as a Decoded with QTGMC, the Deinterlacing is not as good as using Avisynth. The problem is in QTGMC that can use only software decoders or is a general problem with Staxrip with some settings? If i use GPU in Ripbot, the results are good like software. Probably my error is when I use PRORES instead of NVENC h.264. Can someone tell me the best settings to achieve superb quality with NVENC h.264? My card is a RTX3070
P.S. I want to try AutoAdjust for the colours. When the software ask if the input is TV Range or not, where i can see if the input is TV RANGE or not? When I select output, I have to select TV RANGE or not?
In the meantime I have another question. I have deinterlaced with QTGMC various dvd that I want to upscale. From the file info:
If I want to upscale it is necessary to convert colours from BT601 to BT709 or not?Formato : ProRes
Formatoversion : Version 0
Formatoprofile : 422
Codec ID : apcn
Durata (ms) : 1h 51mn
Bit rate mode : Variable
Bit rate : 61.0 Mbps
Larghezza : 720 pixels
Altezza : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Costante
Frame rate : 59.940 (60000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:2
Scan type : Progressiva
Bits/(Pixel*Frame) : 2.945
Stream size : 47.4 GB (100%)
Writing library : fmpg.
If I have to convert colours, can you give me a line code? Someone told me that HDRMatrix is better than ColorMatrix.
Let me know
TBC Questions
By Mockingbird in forum Capturing and VCRReplies: 17Last Post: 27th Jun 2022, 00:42 -
Questions regarding Super8 and Mini8 captures... post-processing mostly.
By inferno480 in forum Video ConversionReplies: 0Last Post: 7th Jun 2020, 07:57 -
I have some questions re LinkedIn
By vhelp in forum Off topicReplies: 11Last Post: 24th Oct 2018, 07:38 -
a few questions about h264
By psyde in forum Video ConversionReplies: 7Last Post: 6th Jan 2018, 06:00 -
Potplayer Questions
By drstew12 in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2018, 12:45
