Hi, [...]
however
I wonder if using ffmpeg is there a commandline to re-encode a video file that - for example - is rotate 90 degrees, but tell to ffmpeg to use the same
birtare-codec-resolution-framerate-croma subsampling-aspectratio ?
or for example, if I need to reprocess the video part using avisynth, the re-encoding can be do using the same birtare-codec-resolution-framerate-croma subsampling-aspectratio?
see if this is what you want - https://stackoverflow.com/questions/44875053/how-can-i-reencode-a-video-to-match-anoth...-codec-exactly
ffmpeg reencode damaged file
By hedwig in forum Video ConversionReplies: 0Last Post: 30th Jun 2021, 18:03 -
[ffmpeg] why using AAC codec the bitrate is alwais VBR? I need CBR
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 11th Sep 2020, 15:02 -
ffmpeg -framerate
By koberulz in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2020, 12:51 -
Wrong framerate during FFMPEG concatenation
By qo4on in forum Newbie / General discussionsReplies: 21Last Post: 28th Apr 2020, 06:57 -
lossless framerate change with ffmpeg?
By BabaG in forum Video ConversionReplies: 7Last Post: 8th Feb 2020, 19:53
