The subject line is an error I made but I don't know what I selected that, for instance, changed the proper name Lumpkin and got Pumpkin in Subtitle Edit. It had to be by running Fix Common Errors. I don't know how to do much else.
I did not want any changes at all for the proper name or names found so I've had to go over the whole subtitle to find these errors.
The Fix Common Errors list is quite long.
If a name gets changed due to a ocr then what you should do is go to options/word lists and check in ocr fix list for the name and remove it so it doesn't get auto fixed.
Thanks for answering. I know I wasn't doing anything with OCR for VOBs with Tesseract and the like.
Do things get added to the list you mention automatically? I just don't know which process is involved. The only thing
I recall is that on one pass I had all the boxes checked on Fix Common Errors, then reverted to the default. I keep good backups daily and maybe should have just done what I do in a day over. These manual editing jobs to make subs accurate I do an hour or 90 mins a day-- it's not a job, it's an avocation.
But some subs I've gotten from third parties have not been originals since they have some really peculiar errors no one checked. -
I'll call this solved as having run spell check and using the defaults in error. Thinking through it, that had to be what it was.
Using the Merge lines function in Subtitle Edit gives overlap errors
By loninappleton in forum SubtitleReplies: 4Last Post: 13th Apr 2022, 16:59 -
Fix split line indications in Subtitle Edit
By loninappleton in forum SubtitleReplies: 0Last Post: 14th Feb 2022, 13:49 -
Fixing line splits on an SRT in Subtitle Edit
By loninappleton in forum SubtitleReplies: 1Last Post: 13th Jan 2022, 19:12 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
Any free software for fixing DVB transmission errors?
By Gameshow Host in forum Video ConversionReplies: 2Last Post: 8th Sep 2019, 11:54
