The Steam Deck in portable mode has a max resolution of 720p. That looks good on the Steam Deck but bad on a TV for triple A PC games. So I was thinking I could instead use a VR headset with the SteamDeck for 2D games which gives you the equivalent of a 100" or larger screen but I assume because the actual lenses are small then the picture will look similar or better than it does on the Steam Deck because a picture's quality looks better the smaller the physical screen size is. Thoughts and what headset would you recommend for the best picture quality and comfort?
My thinking is that the Steam Deck and VR headset or AR headset such as Nreal Air will be a good alternative to an expensive monitor and gaming PC due to graphics card still being overpriced due to the shortage.
Results 1 to 1 of 1
Is a VR headset better for watching 2D 4K Bluray remuxes than a TV?
By VideoFanatic in forum VR Player and HardwareReplies: 6Last Post: 28th Mar 2024, 22:04 -
VR headset matching eyes that need glasses
By Skaperen in forum VR Player and HardwareReplies: 8Last Post: 3rd Aug 2022, 08:04 -
Oculus RIFT S VR headset and some old 3D video files
By parkerhome123 in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2020, 22:02 -
Finding audio steam details for hundreds of video files in a folder at once
By kingmustard123 in forum EditingReplies: 2Last Post: 14th Jan 2020, 04:47 -
RECentral: Audio Steam Not Capturing / Saving
By bzowk in forum Capturing and VCRReplies: 4Last Post: 27th Jun 2019, 00:00
