I have been trying to get ECDC to recognize my video files for a couple of days now. I have tried converting my files, and some stock avi files with TMPGnc, mpeg corrector, you name it. Still no luck. EACD continues to tell me that I am using an incorrect file format, does not comply with phillips white book standards. What is it I'm overlooking? I'm thinking this really shouldn't be quite that hard to do. A gentle nudge in the right direction would be appreciated.
Hmmmm
If they are SVCD MPEG files , you will need to install the MPEG 2 codec available from the Tools section on this website!!!
Hope that helps!"If hustling is deviance in the eyes of the lord, then in my realm he is blind"...B*Tip - Back in the day! -
That didn't work either. When I went to the roxio discussion boards, someone else had a similar problem and the reply was that you have to make sure that there is an audio file and a video file. The mpegs I am using have audio in them. Does this make sense.
Solved my problem!!!
I quit trying to burn with ECDC and switched to NERO. Works great
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
