I put together a capture station with 2 Sony BVW-75 Betacam decks, 2 BVR-50 TBCs, and a AJA Kona LHi card with an iMac Pro. I connect the component outputs of the deck I want to use to the capture card. I use the composite output of the deck for secondary monitoring. Using the BVR-50 I can adjust video and chroma levels and setup in the composite and component signals. But hue only changes in the composite signal not the component. That is true whether I use the BVR-50s or the onboard hue adjustment. Does anyone know if that is normal for the BVW-75 / BVR-50s? Do I need to do something different to adjust hue in the component signal?
I don't know that particular device but what you are seeing makes sense. In a composite signal the chroma carrier uses a polar coordinate system where the phase of the carrier determines the hue, the amplitude the saturation. You can easily change the hue by phase shifting the carrier or the chroma burst reference. But component uses a Cartesian coordinate system where changing the hue is much more complicated.
VOB2MPG doesn't work on Windows 10
By armyofquad in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 27th Dec 2024, 18:25 -
Betacam J3 Sony output as 16:9
By Loganp in forum Newbie / General discussionsReplies: 12Last Post: 27th Feb 2022, 12:25 -
subtitles doesn't work?
By knave in forum SubtitleReplies: 1Last Post: 25th May 2020, 09:04 -
mClean doesn't work with staxrip
By SomeoneNeutral in forum RestorationReplies: 24Last Post: 25th Aug 2019, 17:41 -
Betacam Component Capture advice needed.
By Gibson767 in forum Capturing and VCRReplies: 13Last Post: 19th Aug 2019, 22:34
