I bought a second hand copy of Divergent. At around 20 minutes the audio goes out of sync by about 15 seconds at around the 20 minute mark. It is perfect for the first 20 minutes. Is there a way to fix this?
I know I can adjust the audio sync in pot player to compensate, but I'd rather fix it than have to adjust the sync manually every time I play the movie.
10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU
I think your audiostream is from another movie release (g.e. Cinema vs extended version).
Get the correct audiostream and remux it with your video. -
Divergent only has a theatrical release. But I get the gist - the audio is not "repairable" per se.
Playing back PCM (44,100 kbps) audio tracks on blu-ray player = out of sync
By digitalfreaknyc in forum Software PlayingReplies: 19Last Post: 3rd May 2022, 01:48 -
Matrix Resurrections Bluray - Can I rip with an old Pioneer Bluray writer??
By projinf3d in forum Blu-ray RippingReplies: 3Last Post: 11th Apr 2022, 03:54 -
Sync audio/video of Animation/Cartoon Bluray -> video speed VS audio speed
By precipizio in forum Blu-ray RippingReplies: 4Last Post: 14th Dec 2021, 11:07 -
DVDs are playing out of sync…
By DBR70 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st Oct 2021, 09:54 -
Audio channel mapping for BluRay audio to FLAC using eac3to
By calvinpn in forum AudioReplies: 3Last Post: 31st Jan 2020, 06:49
