Recently I needed to play some colorfull videos in black and white mode.
It is possible directly in PotPlayer?
Or some simple AVS command is needed? Thanks.
I got this far:
In PotPlayer:
Preferences
-> Filter Control
-> Video Decoder
-> Built-in Video Codec/DXVA Settings
-> Use DXVA
-> Checked
-> DXVA2 Copy-Back
-> Select D311 with the GPU
-> Avisynth
-> Enable AviSynth processing
-> Checked
-> Add "potplayer_source()"
-> Checked
-> Leave other checkboxes on default
-> Load Script
-> Select or copy the avs script below
Then I set only this simple AVS script:
greyscale()
So, do I get different results if I use some 'text' parameter in this function (http://avisynth.nl/index.php/GreyScale) ?
I need help hoe to get it work with those "Rec???" parameters. Thanks -
Thanks.
Is there key for a quick reset also?
I only see +/- Y/U here: https://shortcutworld.com/PotPlayer/win/PotPlayer_Shortcuts -
HELP: S-VIDEO black and white via Hauppauge capture - but in colour on TV?
By lagger in forum CapturingReplies: 22Last Post: 2nd May 2022, 15:25 -
Captured video is in black and white (NTSC vs PAL problem?)
By Helena in forum CapturingReplies: 19Last Post: 15th Jul 2021, 16:17 -
Potplayer doesn't play this video
By ConverterCrazy in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2021, 09:14 -
Hi8 to PC video is black and white
By MPvnX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 4th Feb 2021, 10:51 -
PotPlayer video scale 100%
By heavydoody in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2020, 10:46
