  1. source video is x264 1080 29.970 fps MBAFF Top Field First.
    i want to encode to 720p 23.976 fps. with tivtc or qtgmc bob + srestore make the credit text become weird and some frame missing.
    Menu ID                     : 1 (0x1)
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L4.1
    Format settings, CABAC      : Yes
    Format settings, ReFrames   : 4 frames
    Codec ID                    : 27
    Duration                    : 1mn 38s
    Bit rate mode               : Variable
    Bit rate                    : 34.3 Mbps
    Maximum bit rate            : 38.0 Mbps
    Width                       : 1 920 pixels
    Height                      : 1 080 pixels
    Display aspect ratio        : 16:9
    Frame rate                  : 29.970 fps
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : MBAFF
    Scan order                  : Top Field First
    Bits/(Pixel*Frame)          : 0.552
    Stream size                 : 403 MiB (92%)
    example text on video source
    result encode with tivtc or qtgmc bob + srestore, the credit text become weird. it like the line is gone or not.
  2. I don't see anything. Can you be more specific than "weird"?
  3. Originally Posted by exekutive View Post
    source video
    result use qtgmc bob + srestore 23.976 fps
    the text line become blur.
  4. Either it's the qtgmc or 720p resizing. Send script and sample of the original sourcr
  5. sample is the most important part, since the source might not be interlaced at all but just encoded as MBAFF to be blu-ray standard conform,...
    (or it might be a wild mix of progressive, interlaced and telecined content,...)
  6. Of course the text becomes blurry. There's barely enough resolution at 1920x1080 to make it legible. Reducing the frame size to 1280x720 is only going to make it worse.
  7. Exactly what jagabo is saying. This has nothing to do with encoding. I simply resized your source image by 66.6% (1080->720) and it came out "weird".
