Hi everyone,
I have a MP4 video that has vobsub file as subtitles. Is there a way that I can extract it and convert it into srt file . I've tried everything including MKVtoolkit and MKVextractor Gui, but they only work on MKV format, and if I try to convert the MP4 into the MKV, I'll lose the vobsub file. I did try Subtitles Edit but as I tried to import the video, it told me that I need DVD or Bluray format to do so, and since I can't extract the vobsub, I can't use that option either. It seems like I run out of idea of what to do. Anyone can help????
Here is the mediainfo:
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 2.06 GiB
Duration : 45 min 6 s
Overall bit rate : 6 544 kb/s
Writing application : YH Private Tool ver 2.3
Comment : Credits to CHDWEB
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Bit rate : 6 333 kb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.031
Stream size : 1.99 GiB (97%)
Title : Video#Immortal Samsara
Language : Chinese
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 61.2 MiB (3%)
Title : Audio#Immortal Samsara
Language : Chinese
Default : Yes
Alternate group : 1
Text
Format : VobSub
Codec ID : mp4s-E0
Codec ID/Info : The same subtitle format used on DVDs
Duration : 41 min 57 s
Source duration : 40 min 6 s
Bit rate : 16.4 kb/s
Stream size : 4.69 MiB (0%)
Source stream size : 4.69 MiB (0%)
Title : ViESUB#
Language : Vietnamese
Default : Yes
Forced : No
Alternate group : 3
Any help would be greatly appreciate!!!!
Closed Thread
Please do not open another thread,one thread is enough,this thread is closed.Continue here-
https://forum.videohelp.com/threads/406755-Help-How-to-extract-vobsub-from-MP4I think,therefore i am a hamster.
how to extract mp4 from gem file
By shakila21 in forum Video Streaming DownloadingReplies: 41Last Post: 2nd Jul 2023, 20:22 -
Help? How to extract vobsub from MP4
By hnle1988 in forum Video ConversionReplies: 12Last Post: 24th Aug 2022, 21:34 -
Vobsub: Extract Position and Duration
By Valit in forum SubtitleReplies: 1Last Post: 6th Jun 2020, 05:09 -
How to extract CC from an mp4 file and then remux them back after edit
By RoyZ7 in forum SubtitleReplies: 0Last Post: 5th May 2020, 20:35 -
Easiest way to mass convert VOBSUB to SRT without extract/remux?
By Chrushev in forum SubtitleReplies: 3Last Post: 31st Jan 2020, 19:18
