I have some PAL discs that I want to burn, but my Playstation only supports NTSC. Are there any cheap and reliable players that can play both PAL and NTSC standards?
Results 1 to 9 of 9
if you copy & burn the dvd with dvdfab, the dvd will be region free.
but if still need to get a dvd player that plays both PAL & NTSC discs then
try 220 electronics.com - https://www.220-electronics.com/ -
B&H Photo and Video has a multi-region, multi-system Philips DVD player.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Most Philips DVD and Blu-Ray players can be made region free and work fine with all the DVDs I have tested. Unfortunately they are no longer being made....
DVD players can't play MKV files. However, the built-in media players in many Smart TV media players will play them from a USB flash drive.
MakeMKV is a simple solution for creating MKVs from DVDs or mounted DVD ISOs.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Can I get the hi-fi stereo audio from a PAL VHS tape in an NTSC player?
By ItaloFan in forum AudioReplies: 6Last Post: 18th Aug 2022, 21:52 -
CED, PAL on NTSC player, speeds seems too normal?
By anonymoustly in forum MediaReplies: 24Last Post: 12th Mar 2022, 14:01 -
PAL and NTSC hi8 player
By jonbang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 18th Mar 2021, 15:51 -
Converting NTSC->PAL Interlaced DVD Back To NTSC 24FPS???
By SegaSonic91 in forum DVD RippingReplies: 7Last Post: 3rd Oct 2020, 00:55 -
Betamax Player Dual Format - NTSC & PAL
By johnoshea02 in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2020, 13:40
