Results 1 to 9 of 9
    Apr 2015
    Would anyone be able to help me understand how to grab video from this site?
    www.abcnewsvsource.com
    yt-dlp doesn't play nice with the web url or the amazonaws url that I can retrieve from the inspector.
    URL for a video example
    https://www.abcnewsvsource.com/home/815227/817292
    An example of the URLs from inspector
    https://abcmam-masstech-prod.s3.amazonaws.com/060a2b340101010101010f0013-000000-613cd2...VVz7S0Keo0w%3D
    Any help greatly appreciated!
  2. Use the amazonaws link with referer with curl
    Example
    curl --referer "https://www.abcnewsvsource.com/" "https://abcmam-masstech-prod.s3.amazonaws.com/060a2b340101010101010f0013-000000-037ba05b747dbeb3-060e2b347f7f-2a80__10998941__NYBE17680I.000.mp4?AWSAccessKeyId=ASIAQTDI4ECZDEVVNFOQ&Expires=1661443434&Signature=SqA8mHGpiLzEqz%2FYPJzCAy8qXz8%3D&x-amz-security-token=FwoGZXIvYXdzECoaDM9VbF7mCoGqo%2B0UfSK5Af2%2Ba0Zhw8pOu%2BUWq2R8kBms9ZSSS4CS9%2FZz494UaaR03I4saPChUaqDJFz0R5ofxmD5CZMdt17MNCXOLxNRTflwfeLm%2FnUl8MpGszNUDICZmBfGa48z0ZjfDX5tiIrzzJSd2pQcP24t6%2F%2FDwI8LJaBmmIow3HbR7Ft2Rf6%2Fl2nBLbxYyPIpt%2FlizuggJQp1UGhmE%2FtcsET%2BNLtIKphw98rnTbxpY3wvJHa04DP0QBXS%2BkubXOFXvu5EKOr0k5gGMi3rqnG%2FqIKO5vR2kgpZKp3q2Fb1JbOUJi7UdbYjy%2BZEfNWwco0p1bDVf3HRULM%3D" --output nine11.mp4
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
    Apr 2015
    Thanks so much!
    vegeta, you are an endless source of inspiration
  4. Originally Posted by mikeru View Post
    Thanks, you made my evening
    click click2
    Nov 2023
    Berlin
    Hiya Mike and Vegeta!!
    Thanks so much for the help. This link has worked for me for a year but now I get the following error message:
    ERROR: [generic] None: Unable to download webpage: HTTP Error 403: Forbidden (caused by <HTTPError 403: 'Forbidden'>); please report this issue on https://github.com/yt-dlp/yt-dlp/issues?q= , filling out the appropriate issue template. Confirm you are on the latest version using yt-dlp -U
    File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/runpy.py", line 197, in _run_module_as_main
    return _run_code(code, main_globals, None,
    File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/runpy.py", line 87, in _run_code
    exec(code, run_globals)
    File "/usr/local/bin/yt-dlp/__main__.py", line 17, in <module>
    File "/usr/local/bin/yt-dlp/yt_dlp/__init__.py", line 1008, in main
    File "/usr/local/bin/yt-dlp/yt_dlp/__init__.py", line 998, in _real_main
    File "/usr/local/bin/yt-dlp/yt_dlp/YoutubeDL.py", line 948, in __exit__
    File "/usr/local/bin/yt-dlp/yt_dlp/cookies.py", line 1269, in save
    File "/Library/Developer/CommandLineTools/Library/Frameworks/Python3.framework/Versions/3.9/lib/python3.9/contextlib.py", line 117, in __enter__
    return next(self.gen)
    File "/usr/local/bin/yt-dlp/yt_dlp/cookies.py", line 1224, in open
    I've tried adding --cookies-from-browser chrome and still nothing.
    My yt-dlp link at the moment is:
    --referer "https://www.abcnewsvsource.com/" "https://abcmam-masstech-prod.s3.amazonaws.com/060a2b340101010101010f0013-000000-000001208decd69d-060e2b347f7f-2a80__7238608__A37397.mp4?AWSAccessKeyId=ASIAQTDI4 ECZER3PWYX7&amp;Expires=1699465131&amp;Signature=F KzDf33ll8XZI5ZtuxMvVm%2Fg9Qk%3D&amp;x-amz-security-token=FwoGZXIvYXdzEGsaDE%2BtiHnwlC2hgUBA7iK5AUpiFJ ymU83TQA%2BKfe97VbKj%2FkHU0IE0y%2F8k2JyMvjbliL9bu% 2B6Ivb5qHI6NNOvI6YqNqMAbEWosGQU%2BPdqb3ODRksRIGIRS 5MBD5zJBvJN1BO1s06RFVsEWIBPtcbnYbeXt742g70pb1lYCTz HdVUQ2JelmpUpcx5qOYXa%2FwO%2BTwx9LJyoApc%2Fs2GqBnn iRtkJwqFhn%2FvrYgYCYpv1UqEvhrYDqxKdpU%2F5nTuto%2B8 P%2B3UbYbpbpi5tWKKvJpKoGMi01Flo2x5ycMJSUNPVcJOLd3r I0KziuimsdrA47qrO5LCQscQj1ZDKnHYwoBM0%3D" --output nine11.mp4
    Would love some help as I am a hopeless noob!!!
  6. [ss]vegeta's post (#2) clearly says to use curl.
    The link still works with curl.
    Nov 2023
    Berlin
    Hiya!
    Thanks for the quick answer. I'm sorry if it's something really simple but it's still not working for me... I put in the below link and get this error message
    yt-dlp --cookies "USER" --no-check-certificate -i -c --merge-output-format mp4 -o "FOLDER" curl --referer "https://www.abcnewsvsource.com/" "https://abcmam-masstech-prod.s3.amazonaws.com/060a2b340101010101010f0013-000000-037ba05b747dbeb3-060e2b347f7f-2a80__10998941__NYBE17680I.000.mp4?AWSAccessKeyId= ASIAQTDI4ECZDEVVNFOQ&Expires=1661443434&Signature= SqA8mHGpiLzEqz%2FYPJzCAy8qXz8%3D&x-amz-security-token=FwoGZXIvYXdzECoaDM9VbF7mCoGqo%2B0UfSK5Af2%2B a0Zhw8pOu%2BUWq2R8kBms9ZSSS4CS9%2FZz494UaaR03I4saP ChUaqDJFz0R5ofxmD5CZMdt17MNCXOLxNRTflwfeLm%2FnUl8M pGszNUDICZmBfGa48z0ZjfDX5tiIrzzJSd2pQcP24t6%2F%2FD wI8LJaBmmIow3HbR7Ft2Rf6%2Fl2nBLbxYyPIpt%2FlizuggJQ p1UGhmE%2FtcsET%2BNLtIKphw98rnTbxpY3wvJHa04DP0QBXS %2BkubXOFXvu5EKOr0k5gGMi3rqnG%2FqIKO5vR2kgpZKp3q2F b1JbOUJi7UdbYjy%2BZEfNWwco0p1bDVf3HRULM%3D" --output nine11.mp4
    And I get this error:
    During handling of the above exception, another exception occurred:
    File "/usr/local/bin/yt-dlp/yt_dlp/__init__.py", line 1001, in _real_main
  8. example
    curl --referer "https://www.abcnewsvsource.com/" "https://abcmam-masstech-prod.s3.amazonaws.com/060a2b340101010501010f1013-000000-dd0d1ba599578505-c3a9186024a8-ef06__16319093__WHITE%20HOUSE%20PRESS%20BRIEFING%20STIX.mp4?AWSAccessKeyId=ASIAQTDI4ECZOYPVBKL4&Expires=1699521128&Signature=8xBAA2LsfJwUnV%2FwE8vEGWMvmkc%3D&x-amz-security-token=FwoGZXIvYXdzEHsaDNjy7agLJTrdQuVbIiK5ASpirE8mzjZuoAAGog49QdwkvVlkhpP7NUaTPBoJpItZYFsud%2F60Pc2APG7Ofhm3abGyXcVajL4EE4CAQPXiuz6M2RiANz9eVqlSDI9b2Vi7jG9F%2BX2ChY1Z2gEbJNrhAASFP5M12%2Fk1oz0CQRYzGndaUUXNcYJHavGjBIiV647SB9jK%2FB%2Fx5pYfb0%2B%2ByPh73LvYVll7FFZiggGNdl2tGdxs8dIf5ZCWmFblCEMegKSvRjAXHVw62W2mKOj%2Bp6oGMi1GpYBlBgY%2FajfL%2FawIRsE0yN49ZOndxzDDxo77eD3Yf55%2FG0EcKPm30wmnxMc%3D" --output nine11.mp4
    Nov 2023
    Berlin
    Hiya ElCap,
    Thanks guys for your help! I think I was just using the wrong URL from the inspector for a different video!! Thanks so much
