So I tried loading an .mkv onto a USB and playing it in my Blu-Ray player. However it said either unsupported or unknown video codec. I looked up my Blu-Ray players model (LG BP-175) and it said it would play .mkvs but anyway I decided to use ffmpeg to remux my mkvs to mp4s. I do this and I try playing it again on the Blu-Ray player. It gives me the same message. I am able to play other mp4s though, so I decide I need to actually transcode the file. That's what I did. I transcoded the mkv file to an mp4 and there we go, success! However, when I played it on my Blu-Ray player I was getting weird glitch frames for a few seconds on certain parts of the video. But when I play the file on my PC at the exact same timecodes I don't run into the issue.
Does anyone know what might be causing this? I wanted to just remux the mkvs to mp4s so I could do it fast but since that doesn't work transcoding is my option. But that also sucks because of glitchy frames... that only appear when playing it on my Blu-Ray player. Any help would be appreciated.
Results 1 to 17 of 17
Blu-ray players have limitations on the AVC settings. You have to stay within those limitations. Keep away from too many consecutive b-frames, too many reference frames, too high a bitrate, etc.
See Profiles and Levels:
https://en.wikipedia.org/wiki/Advanced_Video_Coding#Profiles
https://en.wikipedia.org/wiki/Advanced_Video_Coding#Levels
I believe BD is limited to High@4.1. -
If you put a High@4.2 mkv file in a regular blu-ray/tv player and it will say the file is unknown or unplayable even if all the other specs are blu-ray compatible.
Actually I think I figured something out that might be the issue. Maybe I'm still wrong but worth bringing up. I was looking through the links and looking at the max bitrate. Then I checked the bit rate of the .mp4 file and it's 1967kbps. That sounds like the problem right there. I just don't know why it wasn't showing it on my PC.
General
Complete name : G:\Videos\file1.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 307 MiB
Duration : 21 min 45 s
Overall bit rate : 1 976 kb/s
Writing application : Lavf59.25.100
Video
Format : AVC
Format profile : High 10@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Bit rate : 1 838 kb/s
Width : 1 912 pixels
Height : 1 072 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.036
Stream size : 286 MiB (93%)
Writing library : x264 core 164 r3095 baee400
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 21 min 45 s
Bit rate mode : Constant
Bit rate : 132 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 20.2 MiB (7%)
Source stream size : 20.2 MiB (7%)
Language : English
Default : Yes
Alternate group : 1 -
Your profile looks really wrong,it say high10@l4,should read high@L4.
10 bit AVC is not supported by the Blu-ray spec. And b-pyramid isn't fully supported either. Some sample x264 command lines for Blu-ray compliance:
https://sites.google.com/site/x264bluray/home/1080i-p
Note that authored Blu-ray discs require a full 1920x1080 frame but when playing mp4 files other sizes (like your 1912x1072) are usually supported. The same is true about many other settings. But staying close to the spec will increase you likelihood of successful playback. -
Okay so I ended up using the preset "Join images at 1920px width to MP4 video" on FFmpeg Batch AV Converter and now the file plays without any glitchy frames!!! The only thing is, the audio is kind of off, but I believe all I need to do is chance this part "-c:a aac -b:a 64K" in the command.
As you seem to be using FFMpeg Batch AV converter you could copy and paste this in the 'Parameters' area and press "Sequential encoding":
Code:-map 0 -c:v libx264 -preset slow -profile high -level 4.1 -bluray-compat 1 -crf 19 -pix_fmt yuv420p -r 25000/1000 -x264-params keyint=24:open-gop=1:vbv-bufsize=30000:vbv-maxrate=40000 -c:a copy -c:s copy
Glitchy Hi8 Tapes
By kernelfree in forum Capturing and VCRReplies: 3Last Post: 22nd Aug 2022, 16:50 -
i7-9700 CPU yet glitchy laggy editing of 4k ??
By GoodEnough in forum Newbie / General discussionsReplies: 6Last Post: 8th Dec 2020, 21:25 -
Weird Artifacts when extracting video frames to png in ffmpeg
By Blackcero in forum Newbie / General discussionsReplies: 10Last Post: 7th Jul 2018, 11:32 -
Weird 2-frames issue with Aegisub or mkvmerge
By eamon in forum SubtitleReplies: 0Last Post: 24th Mar 2018, 10:29 -
Aegisub timed font enlargement is glitchy
By Ashien in forum SubtitleReplies: 0Last Post: 22nd Nov 2017, 04:13
