I'm not asking about how to pirate anything, I have for years removed my iTunes purchased files DRM for Archive purposes (same as everyone does w/ DVD, BD, UHD etc). Recently iTunes has added on some files HDR 10 Compatible Meta Data.
I'm using TunesKit M4V Converter (still re-encodes the audio but can live w/ that). I appear to lose ALL HDR10 Meta Data on the 1080 files that include this.
1080 iTunes DRM File
1080 TunesKit DRM Removed (along with HDR 10 Meta Data)Code:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : @L23.1 / @L17.9 / @L13.4 / High@L4 MultiView_Count : 1 / 1 / 1 HDR format : SMPTE ST 2086, HDR10 compatible Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : drmi / avc1 Codec ID/Info : Advanced Video Coding Duration : 7 min 47 s Bit rate : 5 213 kb/s Width : 1 472 pixels Height : 1 072 pixels Display aspect ratio : 1.373 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.138 Stream size : 290 MiB (97%) Title : Core Media Video Language : English Encoded date : UTC 2020-11-20 07:03:38 Tagged date : UTC 2020-11-20 07:03:46 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Mastering display color primaries : R: x=0.823400 y=0.021760, G: x=0.108800 y=1.179120, B: x=0.367620 y=0.327040, White point: x=0.991900 y=0.126240 Mastering display luminance : min: 220812.0482 cd/m2, max: 230342.7257 cd/m2 Maximum Content Light Level : 38263 cd/m2 Maximum Frame-Average Light Level : 7257 cd/m2 Codec configuration box : avcC
Is there anyway I can extra that HDR 10 data and remux it into the DRM free file? Or is there any other solution I am not aware of?Code:Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 7 min 47 s Bit rate : 5 213 kb/s Width : 1 472 pixels Height : 1 072 pixels Display aspect ratio : 1.373 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.138 Stream size : 290 MiB (98%) Language : English Encoded date : UTC 2022-07-10 20:11:50 Tagged date : UTC 2022-07-10 20:12:05 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Codec configuration box : avcC
Thanks guys.
Results 1 to 1 of 1
Possible to convert HDR10 to HDR10+?
By ShikuTeshi in forum Video ConversionReplies: 8Last Post: 18th Jan 2022, 16:31 -
Trying to remove the drm protection from itunes video
By shadshood in forum Video ConversionReplies: 9Last Post: 17th Sep 2021, 03:32 -
4K HDR10 > FHD HDR10 weights less than 4K HDR10 > FHD SDR ????
By bokeron2020 in forum Video ConversionReplies: 17Last Post: 17th Aug 2021, 22:47 -
How to Remove DRM Protection from iTunes Videos?
By DVDFab Staff in forum User guidesReplies: 4Last Post: 7th Jan 2020, 14:54 -
How/Where to download non-DRM HD movie? Amazon? iTunes? Elsewhere?
By osullic in forum Newbie / General discussionsReplies: 11Last Post: 5th Nov 2019, 22:31
