Hi,
after i get the keys for this stream i can't decrypt it using mp4decypt
can sameone help me with it
stream mpd :
https://stream.altafser.com/live.mpd
licence url :
https://widevine.altafser.com/
Results 1 to 12 of 12
Have you got the good keys?
Code:8f7affa514c3589035a23a931ed5cc14:09ad6d2cfcc289615348a78350e5bd2d 1a0ae160361f369e7eb77c0ced581331:06916e8f2df9cd034e0b293705331515
the same problem try to decrypt it with mp4decrypt or any other method you have ,
thanks -
If it doesn't work, try with shaka-packager .Code:
mp4decrypt --key 8f7affa514c3589035a23a931ed5cc14:09ad6d2cfcc289615348a78350e5bd2d --key 1a0ae160361f369e7eb77c0ced581331:06916e8f2df9cd034e0b293705331515 yourfile.mp4 decryptfile.mp4
/media # packager in=s.mp4,stream=video,output=output.mp4 --enable_raw_key_decryption --keys key_id=8f7affa514c3589035a23a931ed5cc14:key=09ad6d 2cfcc28
9615348a78350e5bd2d
[0821/125226:INFO:demuxer.cc(89)] Demuxer::Run() on file 's.mp4'.
[0821/125226:INFO:demuxer.cc(155)] Initialize Demuxer for file 's.mp4'.
[0821/125226:ERROR:box_definitions.cc(299)] Failure while processing: reader->Read2(&subsample.clear_bytes) && reader->Read4(&subsample.cipher_bytes)
[0821/125226:ERROR:box_definitions.cc(392)] Failure while processing: sample_encryption_entry.ParseFromBuffer( iv_size, (flags & kUseSubsampleEncryption) != 0, &reader) != 0
[0821/125226:ERROR:track_run_iterator.cc(350)] Failure while processing: traf.sample_encryption.ParseFromSampleEncryptionDa ta( default_per_sample_iv_size, &sample_encryption_entries)
[0821/125226:ERROR:mp4_media_parser.cc(743)] Failure while processing: runs_->Init(moof)
[0821/125226:ERROR
ackager_main.cc(551)] Packaging Error: 8 (PARSER_FAILURE): Cannot parse media file s.mp4
check here in player the stream work
https://bitmovin.com/demos/stream-test?format=dash&manifest=https%3A%2F%2Fstream.altaf...ltafser.com%2F -
you added an extra 'A' before '7e+' in the bot search - if you scroll up a few requests, vegeta searched it before you did (but no results)
is the widevine pssh data of the full pssh from the mpdCode:IiRjM2RsWlhSMGRIWmZiVzkyYVdWZk1qQTFOelpmTlRRNU9BPT1I49yVmwY=
FFMPEG Save video from rtsp stream to hls stream
By Wisperrio in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2021, 23:38 -
Why does muxing a video stream into a MKV file change that stream?
By 4L7zHhiyQO3Thui6 in forum Video ConversionReplies: 14Last Post: 11th Mar 2021, 04:45 -
.mpd stream to a viewable stream
By anwarica in forum Video Streaming DownloadingReplies: 3Last Post: 9th Jul 2020, 19:55 -
M3u8 channels not working in Samsoung smart tv but working in vlc player
By alaasl3 in forum Video Streaming DownloadingReplies: 18Last Post: 15th Apr 2019, 04:47 -
Looking for working Adult Stream Capture Tool
By seca in forum Video Streaming DownloadingReplies: 1Last Post: 27th Feb 2019, 02:45
