I have used WonderFox HD Video Converter Factory on Windows to compress the un-necessarily huge video files which phones and cameras produce, and resulting bit rates were very close to what I defined.
However, recently, H264 compression results in video data rates that are usually 2-10X larger than I define, different for each file in the batch, and without any apparent logic. Restarting the app does not change the results. I tried another leading app - Wondershare UniConverter, and had a similar problem - first few runs were OK, and then consistently wrong bitrates. When encoding H265 - results are correct bitrate in both apps. I tried 3 other recommended converters, which had other issues for me, so I never got to testing them beyond a few runs.
Could it be that there's a bug in some H264 encoder underlying both apps (and maybe this encoder was auto-updated and now has a bug)
How do I manage encoders which the conversion apps use?
And which encoder is recommended?
Or even better, can someone recommend a "good" video converter.. ?
- see my next post for what I'd like.
Thanks!
You're doing it wrong. Use 2-pass vbr and set the bitrate required specifically.
Thats what this mode is for - predictable bitrate, predictable file size.
Try Vidcoder/Handbrake -
Cannot mux a H264 with AAC on .TS with Maximum overall bitrate of 8,000
By dogmydog in forum Video ConversionReplies: 36Last Post: 16th Mar 2022, 14:24 -
how to do average bitrate h264 encoding with ffmpeg?
By Anonymous543 in forum Newbie / General discussionsReplies: 38Last Post: 15th Feb 2022, 08:02 -
Wrong PTS times after h264 conversion.
By Budman1 in forum Video ConversionReplies: 2Last Post: 15th Mar 2020, 14:34 -
encoding by staxrip H264 without GPU
By ALMGHARI in forum Video ConversionReplies: 5Last Post: 27th Nov 2019, 08:10 -
HEVC and H264 bitrate/quality equivalency
By philvideofilm in forum Video ConversionReplies: 15Last Post: 29th Sep 2017, 19:41
