Is there a way to play 4k netflix streams on a PC as opposed to a 4k smart tv? I do have a 4K subscription so it shouldn't be much of a problem
Results 1 to 9 of 9
Let Google be your friend.
No browser support except for Microsoft Edge or NetFlix's own app.
Assuming that your PC hardware, graphics and monitor also supports 4K -
You can set your video to be at 4k but you will only get the same dpi as before so no better resolution as compared to what your pc is set to.
Also the internet did help. Basically you get into account settings and set quality to highest. And you have to use edge and shit. Shame they limited it and made it impossible to utilise 4k resolution on any other browser
I watch netflix on a 70 inch 4k tv and 1080p looks fine to me.
Not all shows are 4k,there's still lots of 1080p shows and some 480p,if you have a 4k or higher netflix tells you the resolution.
Netflix and SD sources
By rrats in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2022, 16:04 -
Netflix Videp Download
By azadiyame in forum Video Streaming DownloadingReplies: 3Last Post: 20th Dec 2019, 11:04 -
Netflix download,any idea?
By ghostrewel in forum Video Streaming DownloadingReplies: 2Last Post: 27th Mar 2018, 07:19 -
How to extract Netflix subtitles
By ThePi7on in forum User guidesReplies: 1Last Post: 5th Dec 2017, 18:45 -
How do you rip content of Netflix with subtitles?
By justarish in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2017, 18:10
