If I were to try to play a PAL VHS tape in my NTSC player, I understand that I would not get any usable video. But would I get any audio? If yes, would it be hi-fi stereo or just the linear audio track?
(I also have a multisystem player to get the video, but it only has a mono audio output. I'm wondering if I can get the hi-fi stereo content via my NTSC player.)
You won't get hi-fi since the speeds are different,you will need a pal vhs player with hi-fi unless you find a multisystem player with hi-fi.
The linear audio track will sound like chipmunks because NTSC run faster than PAL.
No, it would run too fast. However, you can buy a multisysten player with hifi (they tend to be cheaper and easier to find than real PAL players, in the US). They both have a good audio output
I am OK with speed differences; I can fix that. I'm just wondering if I'd get any hi-fi audio at all.
Hi-fi only works if the head drum is running at the right speed,any slight speed difference and the hi-fi sound cuts out.
Will NTSC 4.43 VHS tape play well on US players?
By piedpaper in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2021, 05:16 -
PAL VHS tape conversion to computer help
By Adegan in forum Capturing and VCRReplies: 4Last Post: 17th May 2020, 05:41 -
Is a UK PAL video tape compatible with a continental Europe PAL VHS/S-VHS p
By arjaydavis in forum Capturing and VCRReplies: 7Last Post: 21st May 2019, 04:38 -
What do you consider the "best" PAL/NTSC/SECAM VHS player?
By flyboynm in forum MediaReplies: 3Last Post: 7th May 2019, 23:35 -
Importing NTSC tape on PAL camera?
By elangsru in forum MediaReplies: 1Last Post: 23rd Dec 2018, 13:32
